Rio de Janeiro
Rep Power: 0 ![]() |
Hi everyone.
I just started to use Fluent, and I have been trying to study a natural convection in a square cavity with a hot isothermal body. I have different Rayleigh number( e03 to e06) and I'm varying rhe cavity dimensions of the geometry to obten the Rayleigh number that i wish. Doing the simulation for e03 i had the results i expected ( I compared to a literature) But for e04 the temperature and velocity countours were almost the same for e03. I can not understand why. Geometry: a square with the vertical walls adiabatics and the horizontal walls isothermals( hot upper wall and cold bottom wall) centered to the square cavity there is a square hot body(1/3 of the cavity) at the same temperature of the hot isothermal wall) Any suggestion why the results do not change when i change the cavity dimensions? Thanks in advance |
Rep Power: 8 ![]() |
hi
can u send a pic from your geometry? |
fluent, natural convectin |
Heat transfer between two closed cavities with natural convection | Czarulla | FLUENT | 2 | August 5, 2020 12:36 |
Is it possible to model natural convection in a 2D horizontal model in fluent | caitoc | FLUENT | 1 | May 5, 2014 13:32 |
Thermophysical properties for natural convection | Ciefdi | OpenFOAM Running, Solving & CFD | 0 | November 7, 2013 11:44 |
natural convection problem with radiation | jorien | CFX | 0 | October 14, 2011 09:26 |
Coupled vs Seg - Natural vs. Forced Convection | Alex | Siemens | 5 | December 12, 2007 04:58 |
