Why do I receive a fatal signal when I import again a cas and dat? |
March 15, 2018, 18:42 |
Aja
Rep Power: 14 |
Hi
I was running a problem, but Fluent hanged up and I had have to use the task manager panel and close it. When I imported the Cas and data of Fluent again, I faced with the following error (there was not already this error) : No error handler available Error: Cortex received a fatal signal (SEGMENTATION VIOLATION). Error Object: () No error handler available Error: Cortex received a fatal signal (SEGMENTATION VIOLATION). Error Object: () What does this happens? Also, I don't use UDF. Thanks. |
March 16, 2018, 12:14 |
Lucky
Rep Power: 66 |
Segmentation fault means it tries to access a memory location which does not exist.
Does this error happen when you read the case or when you read the data file? Check your file sizes to see if they are corrupt. Maybe you terminated it while it was in the middle of a write. |
March 16, 2018, 15:06 |
#3 | |||
Aja
Rep Power: 14 |
Best. |
March 16, 2018, 16:21 |
Rep Power: 26 |
[General] Fluent CAS and DAT file in PARAVIEW | chauhan | ParaView | 1 | April 9, 2017 00:12 |
opening parallel cas and dat files | darp | FLUENT | 2 | September 1, 2013 10:13 |
error by reading cas and dat data! | Hai Duc | FLUENT | 0 | December 12, 2007 04:56 |
adapted cas file for pre-adapted dat file | jrg | FLUENT | 3 | September 24, 2007 08:43 |
Hidden info in cas and dat files | Dan | FLUENT | 0 | June 7, 2006 07:40 |
