Mass flow rate difference when using profiles |
April 20, 2018, 09:11 |
William Harvey
Rep Power: 8 |
I am currently simulating the airflow in a small room with two identical inlets and one outlet. I'm using a std k-e with enhanced wall function model. No other models are enabled for now. In order to have a fully developped flow at the inlet, I did two simulations. 1) I ran a simulation with a long duct on which I imposed a mass-flow-inlet boundary condition of 0.2388kg/s. I then used the define>profile option to export the velocity profile (x, y and z velocity) at the outlet of that duct. 2) I ran a second simulation with the room i'm testing. I used the profile from the first simulation for my inlets. I used a velocity-inlet boundary condition with a cartesian coordinate system (with the profile from simulation 1 as x, y and z velocity) Problem is, when I monitor the mass flow rate at the inlets, I get the following results: inlet1 = 0.1177kg/s inlet2 = 0.23118 kg/s I am using the Least Squares profile interpolation method. The results are even worst if I use the other interpolation methods. I've tried refining the mesh in both simulations and making the boundary mesh identical with no success. I know I could just modelize the actual duct in the second simulation, but using the profiles would make my live easier in future simulations. Does anybody know how I could make it work properly? Thanks. |
Mass flow rate boundary condition with negative values | hebe2u. | CFX | 1 | December 27, 2016 03:53 |
Calculating mass flow rate at multiphase flows | Kuslo187 | OpenFOAM Post-Processing | 1 | August 21, 2015 18:11 |
mass flow rate in DPM steady tracking | Roule | FLUENT | 4 | June 1, 2015 10:44 |
Mass flow rate through each cell | Babakjingo | Main CFD Forum | 0 | August 21, 2011 03:18 |
Mass flow rate | sepidecent | CFX | 0 | August 9, 2011 00:15 |
