The meaning of the following warning in fluent?
Old   May 9, 2018, 03:58
Default The meaning of the following warning in fluent?
ali
ebtedaei is on a distinguished road
Dear All,
To solve the following warning in Fluent,I increased the maximum number of time steps used to compute a single particle trajectory. But the warning was not solved !!!
"" WARNING: 53.5245% of the total discrete phase mass was not tracked for the expected residence time:
0.000956 s less on a mass-weighted average (which is 0.1525% of their total age or 95.6261% of the last time step).
You may be able to reduce this discrepancy by changing the tracking parameters, that is,
increasing the maximum number of time steps used to compute a single particle trajectory
Please tell me How can I solve this warning? Is there another way to solve this warning?
Best regards,
Ali
ebtedaei is offline   Reply With Quote
Old   May 9, 2018, 05:58
Kushal Puri
Kushal Puri is on a distinguished road
Originally Posted by ebtedaei View Post
Dear All,
Best regards,
Ali
you try to increase the max number of steps to some higher value, as shown in image
Kushal Puri is offline   Reply With Quote
Old   May 9, 2018, 06:40
ali
Thanks for your response,
Sorry I has increased it up to 5000 and also to 500,000 but the warning was not solved !!!
Old   May 9, 2018, 07:03
Kushal Puri
You have the converged flow or you are converging it with DPM. If it is not converged then converge the flow first and then use DPM.
Old   May 9, 2018, 16:22
ali
At first, I solved a converged multi-phase flow of fluids (CFD). Now I want to add particles flow (DPM) to it.
How much should I increase max. number of time steps in DPM model?
Best,
Ali
Old   May 10, 2018, 07:29
Kushal Puri
Best,
Ali
You can start with keeping no of continuous phase iteration to 500 and max no of time step to 2000.
Old   May 10, 2018, 13:55
19snr
susilonr is on a distinguished road
Best,
Ali
Did you made CFD in 3d models? If its yes.. can you tell me how to solved convergn multi-phased?
Can you tell me how to solved converged multi-phase flow? please send by email nurrahmatsusilo@gmail.com
susilonr is offline   Reply With Quote
Old   May 11, 2018, 02:20
ali
I used different multi-phase models such as VOF or mixture and Viscous model of RSM with solution method of SIMPLE or PISO in Fluent.
What is your problem?
Old   July 23, 2018, 05:01
Yatin Suri
y.suri is on a distinguished road
Did you able to resolve this issue? I am getting a similar warning, Please suggest?
y.suri is offline   Reply With Quote
Old   July 23, 2018, 06:57
ali
[No, I'm sorry
QUOTE=y.suri;700109]Did you able to resolve this issue? I am getting a similar warning, Please suggest?[/QUOTE]
Old   December 4, 2018, 08:41
france123 is on a distinguished road
Hey everyone,
I´m facing the same problem. Has someone found a solution?
I also increased the maximum number of steps up to 50000, but still the same warning.
I try to solve a transient simulation of a sedimentation tank.
I would be happy if someone try to help me.
Best regards.
france123 is offline   Reply With Quote
Old   December 4, 2018, 08:46
Yatin Suri
check your input model parameters in DPM model. Most probably double check the mass flow rate. I get rid of this warning by changing my simulation modelling parameters.
I hope it will help.
Originally Posted by france123 View Post
Hey everyone,
Best regards.
Old   May 8, 2019, 01:58
Zaha
Lale is on a distinguished road
I believe the problem is related to the vast numbers of injected particle. How can I reduce them to the specified number?
Lale is offline   Reply With Quote
foamToTecplot360 thomasduerr OpenFOAM Post-Processing 121 June 11, 2021 10:05
[mesh manipulation] refineMesh Error mohsen.boojari OpenFOAM Meshing & Mesh Conversion 3 March 1, 2018 22:07
[Gmsh] discretizer - gmshToFoam Andyjoe OpenFOAM Meshing & Mesh Conversion 13 March 14, 2012 04:35
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
Can anybody help me to solve the list errors while compiling Openfoam 15 on Opensuse 103 32bit coompressor OpenFOAM Installation 0 November 12, 2008 19:53
