Assign Pressure and mass flow rate at inlet in Fluent |
May 9, 2018, 05:13 |
Ahmed Elsayed
Rep Power: 8 |
I was trying to assign the pressure and the mass flow rate at inlet for my case in Fluent, but after some research on the forums here, I've found that u can't do that because it's mathematically over specifying. But someone suggest that i can use UDF to override this part, can this method work? and where exactly i just use it, in mass flow rate condition or in pressure-inlet condition? |
May 9, 2018, 05:54 |
#2 | |
Kushal Puri
Rep Power: 12 |
This supersonic initial gauge pressure will come into picture only when your inlet flow is supersonic. |
May 9, 2018, 05:56 |
Ahmed Elsayed
Rep Power: 8 |
May 9, 2018, 08:12 |
Kushal Puri
Rep Power: 12 |
May 9, 2018, 08:18 |
Ahmed Elsayed
Rep Power: 8 |
May 9, 2018, 10:16 |
Kushal Puri
Rep Power: 12 |
May 6, 2023, 03:26 |
#7 | |
Akshay
Rep Power: 3 |
I have a compressible flow 2D simulation. |
May 6, 2023, 23:09 |
Lucky
Rep Power: 66 |
You need to figure out what Mach number you want. Otherwise, any Mach number greater than 1 is supersonic and there are infinitely many conditions that will be supersonic and give you a mass flow rate.
Once you pick a Mach number, a specific masss flow rate will dictate the static pressure. |
May 7, 2023, 00:27 |
Akshay
Rep Power: 3 |
Sir the case is something like this.
A density based, steady state, RANS averaged, non reacting(cold flow simulation), 2d planar, Spalart Allmaras viscosity model. The air and fuel inlets are perpendicular to each other. The inlets are mass flow inlets(known from the source paper). Here I have turned on turbulence intensity and hydraulic diameter condition and set the intensity to 5%. The materials air is ideal gas and viscosity constant. Mixture hydrogen air density is constant and viscosity ideal gas mixing law. The outlet is a pressure outlet constant at 1 bar ( how do I keep this ? For some simulations I tried I had kept gauge pressure and pressure as absolute pressure). Should I also turn on prevent backflow and target mass flow rate ? The fluid domain is then initialized with equivalence ratio 0.6. The paper says for the mass flow rate inlet of air of 0.5kg/s the highest mach obtained is 1.21. Till now in the flow domain the highest mach obtained is 0.54. We are not understanding where we are wrong. Can you please help us and if you dont mind please share your mail id, it will be easy for me to share the case details. This is for my college project and the deadline is in 72hrs 😵 |
May 7, 2023, 23:26 |
Lucky
Rep Power: 66 |
If it's a college project then you have paid instructors to answer your questions 24/7. Maybe use the resources which you've paid for.
Mach number inside domain means nothing for the inlet. You need the inlet Mach number. And do not use a mass flow inlet and a mass flow outlet, pick one. Fluent always uses gauge pressures, you just have to deal with it. Only thing you can maybe do is set the operating pressure to 0 but it is still technically a gauge of 0. |
mass flow inlet and pressure outlet with target mass flow rate | Zigainer | FLUENT | 13 | October 26, 2018 05:58 |
Total pressure and mass flow boundary condition at inlet | bscphil | OpenFOAM Pre-Processing | 3 | July 9, 2017 14:39 |
Pressure Outlet Targeted Mass Flow Rate | LuckyTran | FLUENT | 1 | November 23, 2016 10:40 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
