Number of Energy Source Terms - Where are the Sources located? |
June 5, 2018, 06:42 |
Mike
Rep Power: 8 |
Hi all,
I'm using Source Terms for simulating a cube with internal heat reactions. When I'm choosing one Source Term the cube gets uniformly warmer. I wonder what happens if I select more than one Source Term. Where are the Sources located? I have already tried it by myself to find the difference between one or more Source Terms but there almost are none. Even by choosing 10 Source Terms with highly different values (varying from 1 to 10,000 W/m^3) the temperature is evenly distributed through the whole cube. Depending on the material I chose there are slightly differences in the temperature, so you can see different colors but the differences are below 1 Kelvin. Neither I found any more informations in the Ansys Help. I hope that someone got some experience in using the Source Terms Thanks and Greets Mike |
June 5, 2018, 17:42 |
Lucky
Rep Power: 66 |
Most likely you have chosen a constant source over the entire cell zone. And if so, there's no difference at all between 1 or 2 or 3 sources if they all add up to the same total volumetric heat rate.
energy source number term |
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 | ordinary | OpenFOAM Installation | 19 | September 3, 2019 18:13 |
Compressor Simulation using rhoPimpleDyMFoam | Jetfire | OpenFOAM Running, Solving & CFD | 107 | December 9, 2014 13:38 |
Problem compiling a custom Lagrangian library | brbbhatti | OpenFOAM Programming & Development | 2 | July 7, 2014 11:32 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
