June 1, 2018, 02:08 |
Uds
Anomymous
Rep Power: 8 |
Hi all,
I am getting an error in fluent solver while trying to revalidate a thesis. Error: \nHaving flux boundary conditions for uds-0 on anode and cathode external contacts is not supported.\nPlease specify value boundary conditions for uds-0 on at least one external contact.\n Error Object: #f I am not able to understand why the fluent is asking for UDS, also when I am trying to make no. of UDS = 0, it shows the error Error: Insufficient number of UDS. 4 required, but only 0 allocated! Error Object: #f Even though I am using the UDF for defining the diffusivities of the species it is asking for UDS, please reply how to remove this. Thank you |
February 20, 2019, 05:22 |
Pooya Razaghi
Rep Power: 9 |
Dear Nishant
Did you solve that problem? |
February 21, 2019, 00:03 |
Alexander
Rep Power: 34 |
model that you are trying to use has UDS, most likely you are using PEM?
there is a description in your error, where you may clearly see what is a problem Code:
Error: \nHaving flux boundary conditions for uds-0 on anode and cathode external contacts is not supported that's it best regards |
When to use User-defined Scalar (UDS) for concentration? | THC | FLUENT | 1 | May 30, 2019 09:04 |
How can I solve dot product field of UDS in fluent? | swtbkim | FLUENT | 3 | November 17, 2017 07:31 |
Set UDS on wall... | fivos | Fluent UDF and Scheme Programming | 2 | July 25, 2014 05:57 |
Calculate UDS flux through the wall | ananth_01 | FLUENT | 0 | August 5, 2013 07:33 |
Doubts UDS Flux, UDS Unsteady for VOF model | kel85uk | FLUENT | 0 | March 17, 2010 08:53 |
