convergence problem
Old   June 19, 2018, 13:50
Default convergence problem
Naveen Kumar Gulla
Naveen Kumar Gulla is on a distinguished road
Im trying to simulate the marine propeller using MRF approach. My solution is not getting converged and the values of epsilon is going like a waves as shown in the attachment. Can i treat it as a converged solution???
Thanks
Last edited by Naveen Kumar Gulla; June 19, 2018 at 20:36. Reason: To mention simulation model
Naveen Kumar Gulla is offline   Reply With Quote
Old   June 19, 2018, 18:17
Amir Shahriari
amir.shahriari93 is on a distinguished road
Firstly can you tell us what are you trying to simulate?
amir.shahriari93 is offline   Reply With Quote
Old   June 19, 2018, 20:39
Naveen Kumar Gulla
Hi Amir,
I'm trying to simulate marine propeller using MRF approach.
Thanks
Old   June 20, 2018, 02:18
Amir Shahriari
1-Calculate your case with double precision.
2-Define monitors for quantities of interest of your simulation and plot them as the solution iterates.
If solution is not converging and monitors show periodic behavior, Probably your simulation has some unsteady features (e.g., Vortex-shedding) and you should solve it in a transient manner.
Old   June 20, 2018, 13:49
Naveen Kumar Gulla
If the solution is not converging and monitors show periodic behaviour, Probably your simulation has some unsteady features (e.g., Vortex-shedding) and you should solve it in a transient manner.
Hi Amir,
I have already used double precision option.
And regd monitors I have plotted lift and drag but they are also having periodic nature. I'm trying to validate the base paper and he used steady state analysis.
Thank You
Convergence problem in Fluent for quenching process kaeran FLUENT 4 December 1, 2014 02:14
Rotate frame reference convergence problem! wjy-c CFX 2 September 26, 2014 06:03
Centrifugal pump OpenFOAM, convergence problem, ANSA model RDD OpenFOAM Running, Solving & CFD 0 July 5, 2014 09:12
Convergence Problem in Axisymmetric Periodic Flow atheresia FLUENT 3 February 10, 2014 03:00
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 01:17
