c& nozzle flows with heat transfer process
Old   July 20, 2018, 02:35
Default c& nozzle flows with heat transfer process
Sai Krishna
Sai Krishna is on a distinguished road
i want to simulate an experiment in fluent in which hot air flows through nozzle and outer wall temperature is measured. nozzle is made up of steel. i made nozzle geometry(axi symmetric) in icem cfd providing thickness for the walls. the problem is when i did simulation in fluent, i am not able to get the temperature gradient in the solid walls and whole body its showing at the same temperature of the gas (which i gave as input.)
my doubts are:
1.i should get a boundary layer on inner side of the walls, which i am not
getting.
2.temperature gradient in steel is not occurring.(steel thickness is 5 mm)
3.as the experiment is conducted not in controlled environment, i provided a
domain with pressure far field condition with pressure as 1 bar and mach
number as 0.001(since i assumed the air is in almost stand still condition).
but this provided very vague results in which the body temperature is
raising more than the entry fluid temperature.
my boundary conditions are
4 bar pressure, 4 kg/sec mass flow rate, 1650K temperature - inlet
gases are exit to atmosphere
models - k-epsilon, realizable, enhanced wall treatment , thermal effects.
i did 4 revisions for this, none of them gave the satisfied results.
help in this will be greatly appreciated
thank you.
Sai Krishna is offline   Reply With Quote
fluent, heat transfer boundary, nozzle simulation
modelling heat transfer inside a jet nozzle Taruk Main CFD Forum 1 June 2, 2017 10:19
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 08:44
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
How can I increase Heat Transfer at Domain Interf? B.Simon CFX 3 October 28, 2008 18:53
