Monitoring Torque Values
Like Tree1Likes
  • 1 Post By Mess
Old   August 26, 2018, 03:45
Arrow Monitoring Torque Values
Ahmed Riyadh Ali
xXAhmedXx is on a distinguished road
Dear all
I am running a transient CFD analysis of the NREL Phase VI wind turbine using FLUENT and I am looking forward to finding out how to monitor the torque value during the simulation. Is there a straightforward method using the GUI or I have to enter a specific UDF.
Thanks.
xXAhmedXx is offline   Reply With Quote
Old   August 26, 2018, 03:50
Mess is on a distinguished road
Originally Posted by xXAhmedXx View Post
Dear all
Thanks.
Hi. You can define a report under solution to monitor torque
Mess is offline   Reply With Quote
Old   August 26, 2018, 03:51
That way u can monitor torque as solutions runs
Old   August 26, 2018, 04:13
Ahmed Riyadh Ali
Hi Mess
The problem is the solver monitor the moment coefficient not the torque force.
Old   August 26, 2018, 04:15
You can also get torque
Old   August 26, 2018, 04:19
From report definition. Its in Nm
Old   August 26, 2018, 04:38
Ahmed Riyadh Ali
Ok, let me check if I am doing it right. is it like this:
Report Definition > New > Force Report > Moment
Then, choosing the wall and define the moment center and axis
Finally, tick the report plot and print to console
Usually, I check the torque from reports when the simulation is done but now it's essential for me to monitor the value during the analysis.
Thanks
Old   August 26, 2018, 04:40
Yeah. Dont forget to write it as well. So u can open the file in excel or whatever u prefer
Old   August 26, 2018, 04:42
If u running 2d. Make sure to set correct depth in reference value. Otherwise, you dont have to edit anything there
Old   August 26, 2018, 04:45
Ahmed Riyadh Ali
Unfortunately, I am still getting the coefficient rather than the torque force.
Old   August 26, 2018, 05:00
Moment coefficients are computed, using the reference values specified in the Reference Values panel. The moment coefficient is defined as the moment divided by ½ ρv2AL* where the density, velocity, area, and length explicitly specified in the Reference Values panel. When you make the value of above equation equal to 1 then the output value for both*moment*andmoment coefficient*will be same
v is squared by the way
Old   August 26, 2018, 05:07
Ahmed Riyadh Ali
Ok, I usually skip the reference panel during pre-processing. So from your comment, I have to specify the reference values in order to get the torque and its coefficient. I will check it and see. Thanks
Old   August 26, 2018, 05:08
Just make that the product is 1
Old   August 26, 2018, 05:15
The easy way is. Multiply the product of that equation with the coefficient to get torque
xXAhmedXx likes this.
fluent
Rotor Torque Prediction jason OpenFOAM Running, Solving & CFD 7 August 16, 2016 09:34
using chemkin JMDag2004 OpenFOAM Pre-Processing 2 March 8, 2016 22:38
SIMPLE algorithm does not converge when using old pressure (correction) values andreasp Main CFD Forum 3 February 9, 2016 21:18
Numerical errors in nested domain with pre-calculated boundary values Arnoldinho OpenFOAM Running, Solving & CFD 3 April 4, 2012 10:31
CFX-5: Monitoring values cfd guy CFX 3 August 29, 2001 21:11
