August 27, 2018, 08:33 |
Executing fluent at an external loop manner
Peter Maroul
Rep Power: 7 |
Hi all.
Just as FLUENT users know, a typical method for solving models is setting and initialization of flow field in FLUENT and getting outputs as post-processing in a Self-programming manner. My question concerning the solution procedure is presented as follows: Can user transfer some output data in a loop manner and then modifying and some solution updates in an external language programming ? Really , is it possible to transfer and modify FLUENT results in an external programming language? Which programming language is suitable for this purpose? Are there any tutorial for this purpose? Thanks in advance for any help and reply. P.Maroul |
August 27, 2018, 21:32 |
Alexander
Rep Power: 34 |
As far as I know you may use option: Starting Fluent In Server Mode.
At this case you may use any language you want. Useful links: https://www.sharcnet.ca/Software/Ans...ent_start.html https://www.sharcnet.ca/Software/Ans...scommands.html I have an experience of using matlab with fluent best regards |
August 28, 2018, 06:55 |
#3 | |
Peter Maroul
Rep Power: 7 |
Special Thanks for your consideration the discussion. Just a question came to me. Did you apply Mathlab software to call Ansys Fluent? In the other words, did you use Ansys Fluent as an internal software called by Mathlab software as an external software? Best Regards. |
Variable inlet velocity in Inlet for external flows using Fluent | Kim yongchul | ANSYS | 0 | April 11, 2018 13:02 |
How to use loop statements in FLUENT journal? | didiean | FLUENT | 2 | December 13, 2017 01:57 |
How do I select solver options for external flow over an aircraft by fluent? | hadieliasi | FLUENT | 5 | May 2, 2011 03:54 |
NACA0012 geometry/design software needed | Franny | Main CFD Forum | 13 | July 7, 2007 15:57 |
