Paralellizing UDF DEFINE_PROFILE
Old   October 23, 2018, 06:56
Default Paralellizing UDF DEFINE_PROFILE
Burak
bluejojoba is on a distinguished road
I would like to give heat flux from a surface depending on timestep. So I wrote an UDF for serial (haven't tried yet if it is working btw), but I am not sure if I need to paralellize it when I use parallel solver.
I would like to use DEFINE_PROFILE as follows:
#include "udf.h"
DEFINE_PROFILE(hf_profile,t,i)
real x[ND_ND];
real y;
face_t f;
if (CURRENT_TIME > 5 && CURRENT_TIME < 8) {
F_PROFILE(f,t,i) = 100;
else if (CURRENT_TIME >= 8 && CURRENT_TIME < 15) {
F_PROFILE(f,t,i) = 150;
How should I need to add #if !RP_HOST or !RP_NODE ? I did not quite understand from the manual if I need to use these parallel functions because I think I am not using global functions.
Thank you in advance,
bluejojoba is offline   Reply With Quote
Old   October 24, 2018, 23:50
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
#include "udf.h"
face_t f;
begin_f_loop(f,t)
	{F_PROFILE(f,t,i) = 100;}
	{F_PROFILE(f,t,i) = 150;}
end_f_loop(f,t)
you don't use x and y variables in your code, so I removed them
you don't need to modify your code to use it in parallel
best regards
AlexanderZ is offline   Reply With Quote
Old   October 31, 2018, 10:42
Burak
Originally Posted by AlexanderZ View Post
#include "udf.h"
face_t f;
begin_f_loop(f,t)
end_f_loop(f,t)
best regards
Thank you AlexanderZ,
But Do I need to write a loop? I would like to give heatflux from one surface only.
udf for one dimensional linear motion based on force maccheese Fluent UDF and Scheme Programming 2 September 1, 2019 02:18
Save output of udf in another udf! JuanJoMex FLUENT 0 February 8, 2018 12:43
UDF Compilation Error - Loading Library - COMMON Problem! Help! robtheslob Fluent UDF and Scheme Programming 8 July 24, 2015 00:53
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 22:14
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 04:01
