November 14, 2018, 10:23 |
Aerodynamic of Projectile
Dzul Fikri Hidayatulloh
Hello
I want to ask if the simulation I did is correct? in this case i simulate about the exterior ballistics of projectile using ansys fluent with Spalart-Allmaras model, i want to get the aerodynamic coefficient of the projectile, i had done with my simulation but i still confuse with it this is some iteration graph of my simulation please help me for my final project hehe and can you explain what is the convergence? |
November 14, 2018, 10:32 |
Lucky
Rep Power: 66 |
Results look good. You can see the drag and lift is asymptotic. What is the issue you are having? You can fine tune and tweak your case by using different grids and settings, but this is a very good starting point.
November 14, 2018, 10:41 |
Is the simulation that I did correct?
I want to find the drag value of the projectile how to get it? |
November 14, 2018, 13:24 |
Lucky
Rep Power: 66 |
You gave a plot of the drag... What's the issue?
aerodynamic analysis, fluent |
Projectile moving inside barrel | cozt | Fluent UDF and Scheme Programming | 3 | June 11, 2019 09:32 |
Coefficient of Drag of a projectile for different Mach Numbers | CdProjectile | FLUENT | 3 | January 12, 2018 17:17 |
Aerodynamic analysis of moving projectile using CFX | sathishfliegn | CFX | 9 | August 7, 2014 06:43 |
Aerodynamic noise analysis with CFX | famarcfd | Main CFD Forum | 0 | December 14, 2010 07:53 |
Aerodynamic noise analysis with CFX | famarcfd | ANSYS | 0 | December 13, 2010 06:27 |
