Rotating channel flow
Old   November 23, 2018, 04:43
Default Rotating channel flow
Lukas Hueckel
derHandballer73 is on a distinguished road
I try to simulate a rotating channel flow in Ansys Fluent.
My channel has the size 125,66 x 20 x 62,8 mm (x,y,z) and z is the rotating axis (x=0).
I use the k-epsilon realizable model with Standard Wall Function. My fluid is air with setup of ideal gas.
Further I used Periodic boundary conditions for my walls streamwise (x-direction) and my side-walls. Both set translational and for the x-direction I set different values of masss-flow-rate.
In cell zones conditions I selceted Frame Motion and different values for roating speed. The bottom and the top wall (y-direction) set to moving wall with an relativ rotational speed of 0 m/s.
For methods I use the default settings.
I attached the profiles of my literature I want to get. The values of mass flow rate, x-velocity , rotating speed etc. are calculatet correctly.
So maybe sombebody can have a look on this settings and has and call help me to get the right velocity-profiles.
derHandballer73 is offline   Reply With Quote
Old   January 4, 2019, 02:45
王莹
Alisa_W is on a distinguished road
Maybe you should post your velocity-profiles here and others can analyse and help you.
Alisa_W is offline   Reply With Quote
Car external aerodynamic with wheel spinning issue hokhay FloEFD, FloWorks & FloTHERM 2 August 18, 2016 04:23
flow depth in channel mahdi1 FLOW-3D 5 May 30, 2013 05:28
gas flow out of a C-D channel ljp FLUENT 0 March 7, 2011 14:32
Yacht in Open Channel Flow andreimour FLUENT 1 October 14, 2010 23:54
Rotating channel flow case file? tstorm FLUENT 0 April 8, 2009 09:40
