January 15, 2019, 18:56 |
how to ignite methane air mixture
Weiqiang Liu
Rep Power: 9 |
hello, all
after 200000 iterations, I failed to ignite the mixture, finally. The inlet temperature is 300K. the maximum combustion temperature is 300K. The reaction model is species transport with laminar finite rate. The gas phase mechanism is GRI 3.0. The surface mechanism is DEDUCHMAN. A lot of methods have been used to ignite the mixture, the most promising method is to patch a 2000k temperature to the whole computation domain including fluid and solid. However, the maximum temperature is decreasing all the way down to the inlet temperature 300k. my case is steady state and I follow all the settings in literature. I am wondering why I can not ignite the mixture? thanks very very much for your suggestions!! weiqiang |
catalytic combustion, igniting mixture, methane |
Ignition of the Methane Air mixture | executor | CFX | 0 | September 16, 2015 10:58 |
Arrhenius coefficients for methane air single step combustion | a.Asadi | OpenFOAM Pre-Processing | 0 | August 20, 2015 03:43 |
How to ignite a mixture reactingFoam | Bombolati | OpenFOAM | 1 | April 25, 2013 05:54 |
Mixing AIR and METHANE | zalho | FLUENT | 5 | February 14, 2013 21:52 |
modelling of flow between methane and air | satya | FLUENT | 5 | April 3, 2009 06:32 |
