February 15, 2019, 03:18 |
Solver Type
gene
Rep Power: 7 |
I would appreciate if anyone could advise me the type of solver to use in the fluent to simulate the following conditions:
An well regulated HVAC system operating in the populated working office desk room. I am interested in the air flow distribution as well as the thermal load generated by each human in order to determine the human thermal comfort. What type of solver should I use and how do I activate and simulate the buoyancy effect of the air. Air Velocity is about 0.2 - 2 m/s. Thank You |
February 15, 2019, 08:46 |
Lucky
Rep Power: 66 |
Not enough info to say... All of the solvers will work. But I would recommend to start with steady, pressure-based until you find out otherwise.
Enable gravity and make sure you select something for the equation of state for density that's not constant. |
February 17, 2019, 08:22 |
gene
Rep Power: 7 |
May I know what equation of state would you recommend
February 18, 2019, 06:45 |
Lucky
Rep Power: 66 |
My recommendation is you pick. =)
Seriously, all of them work (except constant). It's just a matter of how you like to model your problem. |
February 18, 2019, 07:37 |
Moritz Kuhn
Rep Power: 17 |
Material properties --> density -->
* ideal gas * incompressible ideal gas * ... * and not constant value |
February 25, 2019, 21:24 |
gene
Rep Power: 7 |
Thank you so much!
solver type |
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries | NickG | OpenFOAM Installation | 3 | December 30, 2019 00:21 |
fluent divergence for no reason | sufjanst | FLUENT | 2 | March 23, 2016 16:08 |
Modified pimpleFoam solver to MRFPimpleFoam solver | hiuluom | OpenFOAM Programming & Development | 12 | June 14, 2015 21:22 |
[swak4Foam] Air Conditioned room groovyBC | Sebaj | OpenFOAM Community Contributions | 7 | October 31, 2012 14:16 |
singularity? | mihaipruna | OpenFOAM Running, Solving & CFD | 5 | April 24, 2012 17:18 |
