fluent interpolates values between two zones!how to cancel it? |
February 20, 2019, 03:47 |
Rep Power: 7 |
hi every one.
i have a problem in fluent! i have a multi-layer pipe in which there is a core pipe and some porous pipes surround the core pipe! i want to simulate this in 2D-axisymmetric (fluent 18). my problem has 2 different densities( 1 density in core pipe and another density in porous layers! this is the case that really happens in my problem) . i have to collect data from the interface between core pipe and the first layer of porous pipe! but fluent interpolates the density(and viscosity) at the interface that make my answers wrong! how can i fix this??? (also fluent change the WSS at the interface because of the difference between the values of WSS in 2 domains) also i checked the zone id of the interfaces and figured out that the zone id of each interface is the mean value of zone_ids of two adjacent zones!!!!! i attached a jpeg image of the situation. thanks |
Getting different values for defined input parameters in fluent | Sagar7 | FLUENT | 0 | August 29, 2017 13:04 |
Initial values files from Fluent to CFX | Nabu | CFX | 1 | March 17, 2012 05:14 |
accepted values in some fields in fluent setup | zikozaki01 | FLUENT | 1 | February 23, 2012 10:45 |
HELP:How to get the values of U+ through Fluent in near wall region | zhaoxinyu | FLUENT | 3 | April 23, 2010 08:34 |
shear rate values with fluent | IƱigo | Main CFD Forum | 0 | October 17, 2005 06:25 |
