Fluent and Design Points
Old   February 20, 2019, 06:21
Default Fluent and Design Points
Alex
QuantumAJ is on a distinguished road
I've previously asked a question about increasing my Mach number using design points and I have raised some questions.
With each design point, does the 'reference from' change too? For example, for Mach=0.65 the reference value is taken from there, then when it increase to Mach=0.7, does it retain the velocity for M=0.65 or does it update to M=0.7 because it is critical for the drag and lift coefficients.
Also, Mesh adaption, is the adapted mesh retained for each update? as I would like to change the adaption based of the localised shock wave location.
Cheers
QuantumAJ is offline   Reply With Quote
missing case file in some design points using workbench updates PJTsai FLUENT 1 December 28, 2021 05:49
Error Running Design of Experiments in ANSYS Fluent tytrzecki FLUENT 0 April 22, 2018 15:01
An efficient procedure to solve many design points for flow with reaction in fluent jumaah FLUENT 4 May 4, 2017 20:10
exporting data from Fluent in batch mode without exporting entire design point nnvoro FLUENT 5 May 6, 2013 01:51
Ansys Workbench Exported design points kvloover FLUENT 0 April 23, 2012 17:21
