Modeling vacuum suction through pipe in ANSYS Fluent |
February 20, 2019, 13:40 |
Marcus
I am currently trying to model fluid flow through a pipe that is produced through vacuum suction. The amount of suction pressure would be 100 mmHg at the vacuum end. I am currently trying to use a negative gauge pressure for pressure-outlet as the boundary condition and zero pressure at the pressure-inlets for the other ends of the pipe. Is this a proper set up for ANSYS Fluent or should I approach the problem in a different way?
Also since ANSYS pressure is in gauge (Pascal) and the vacuum pressure is in mmHg or Torr, would this be considered absolute pressure and require a conversion to gauge? or do I just assume vacuum is negative gauge and use -13332 Pa? I have read some discussion on changing the operating pressure to 0, but I'm not sure the effect this would have on the system. For some additional background on the model, I am trying to model the flow of air through different suction catheters. I want to primarily assess the amount pressure of the suction end in the different solid models during various states of suction. Additionally, while most catheters are about 40 cm in length the models are only 4 cm to mitigate the complexity of the model. Please let me know if you have any input of need any additional information about the model. Thank you |
February 20, 2019, 14:09 |
Lucky
Rep Power: 66 |
-100 mm Hg at the pressure outlet is the right BC to use. What pressure to use at the inlet? Well what is the pressure at the inlet of the pipe? It's probably 0, but you are the one with the pipe. You know what this number is. Just think about it. What is the pipe inlet attached to?
-100 mmHg vacuum is also a gauge pressure. So, use the same gauge. It depends on the equation of state whether or not the operating pressure matters or not. But you can't set 0 operating pressure and -100mmHg at the outlet because that would be a negative absolute pressure. Gauges are actually much more commonly encountered in everyday life than people think. It's not a made up concept from CFD. |
bime, fluent 17, vacuum |
Fused Deposition Modeling Process Simulation in Ansys Fluent | ttp262 | FLUENT | 0 | October 2, 2018 16:07 |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 13:41 |
2-way FSI in Ansys CFX 15 | LucasGasparino | CFX | 3 | August 6, 2015 03:17 |
gambit in Ansys FLuent 13 | saharesobh | FLUENT | 0 | August 1, 2012 15:30 |
Suction modeling | hamid1 | FLUENT | 3 | January 5, 2011 01:52 |
