March 5, 2019, 09:27 |
Units in 2D analysis
crinoid
Rep Power: 7 |
When using Fluent with a 2D mesh, the results which are shown are per unit of length? I am studying the heat transfer between some tubes in cross-flow with cold air and Fluent computes the pressure drop (pa) and heat exchange (w). Do I have to multiply those numbers by the length of my tubes? Thanks in advance |
March 5, 2019, 23:57 |
Behrooz Jamshidi
Rep Power: 13 |
The answer of your question is completely dependent on the result variable definition and derivation. For example the pressure drop in cross flow is not dependent on the length of tubes while heat exchange is dependent and the value is calculated per unit of length and must be multiplied by the length of tubes. |
March 6, 2019, 05:21 |
crinoid
Rep Power: 7 |
Sounds logic, thank you for your answer!!
March 6, 2019, 09:57 |
Moritz Kuhn
Rep Power: 17 |
Some values like volume, flow rate and volume integrals are calculated with the Reference Depth in a 2D-analysis, which you can change under "Setup" and "Reference Values"
March 7, 2019, 08:14 |
crinoid
Rep Power: 7 |
Ok, thanks!!
Would it be possible that the heat flux was express per units of area (considering pi * diameter * 1 m)? |
March 7, 2019, 08:43 |
Moritz Kuhn
Rep Power: 17 |
By default settings yes.
heat transfer, units |
Urgent - Perform an DISCRETE adjoint analysis in parallel_computation | JPBLourenco | SU2 | 1 | April 23, 2018 11:38 |
Explicit dynamics results for initial condition to another explicit dynamics analysis | KOI | Structural Mechanics | 0 | March 2, 2018 05:16 |
Flutter analysis of compressor blade | sridharabc228 | CFX | 1 | April 13, 2017 20:10 |
ANSYS WORKBENCH Transfer result of one analysis to a new analysis as preload | ingjuanm90 | ANSYS | 0 | July 26, 2016 15:04 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 01:00 |
