May 18, 2015, 02:12 |
Inertial resistance term in Fluent
Harry
Rep Power: 13 |
Hi. I am new to Porous media modeling and I am studying some basics which i will implement with Ansys Fluent. My question is very basic but please i couldn't find answer in this forum.
According to Fluent help, inertial resistance term for homogeneous porous media is C/2*rou*|v|v (where C is the inertial resistance coefficient and 'rou' is density). How is this term derived? Its not the original Forchheimer's term which I read in book of Neild and Bejan and many papers related to flow in tube filled with porous media as C/sqrt(K)*rou*|v|v (K is permeability of porous medium). I wonder if it is a general inertial resistance term applicable for wide range of porous geometries. I believe there will be much difference between Fluent's inertial resistance and Forchheimer equation's resistance term because K is usually very low which will effect results. Please help. |
April 3, 2019, 04:56 |
mohamed ahmed essam
by comparing the terms of the ansys equation with the momentum eqaution you will found in the momentum equation for the porous medium the C/2 is equivalent to 2*C_f/SQR(K) where C_f is the coefficient of friction for the porous medium and it is dimensionless and SQR(K) is the square root of the perimability and its dimension is 1/m by comparing the dimensions they are the same. |
darcy-forchheimer, inertial resistance |
inertial resistance UDF | Arnout Klinkenberg | FLUENT | 3 | June 22, 2011 06:07 |
modeling thermal resistance in Fluent? | gholamghar | FLUENT | 1 | August 28, 2010 12:07 |
few quesions on ANSYS ICEMCFD and FLUENT | Prakash.Paudel | ANSYS | 0 | August 12, 2010 12:07 |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 15:45 |
How Fluent treat the pressure term in imcompressible flow | Ray | FLUENT | 1 | May 24, 2000 16:50 |
