modeling the fluid flow in porous media by Fluent
Like Tree1Likes
  • 1 Post By Mohsen Nazari
Old   May 4, 2005, 03:47
Default modeling the fluid flow in porous media by Fluent
Mohsen Nazari
I need to solve the fluid flow and heat transfer in porous media. my geometry is the simple cavity filled with satureted porous material. i want to solve the free convection in this domain but i have a problem for modeling the porous media and heat transfer by Fluent software. i have a question that: is the answer of fluent in this case reliable.
Mohsen. Nazari
Saeid.doosty1984 likes this.
Old   May 4, 2005, 12:19
Default Re: modeling the fluid flow in porous media by Flu
Evan Rosenbaum
Provided you specify the momentum sink parameters in accordance with the user's manual, the porous media model works well.
Old   May 18, 2005, 04:12
ali
hi please i want to know about the resistances in the porous media in the van Winkle formula in the fluent help didnt write how we can calculate the c for calculation the c2(inertial resistance) please i want to have table or diagram for c also i want to ask is it possible to use porous media for the electrofilter guide plate
Old   November 17, 2014, 07:53
M.Suresh kumar
Suresh Msk is on a distinguished road
Originally Posted by Mohsen Nazari
;120372
Mohsen. Nazari
How can i model a porous medium in Ansys fluent???
Suresh Msk is offline   Reply With Quote
Old   July 23, 2016, 05:10
Question Modelling heat flow in porous media in Fluent
mm
mmunige is an unknown quantity at this point
Dear all,
I am modelling heat transfer through a porous medium (from hot air to porous medium), have defined porous medium in fluid cell zone, resistance coefficients,
porosity, heat transfer coefficients since i am using non-equilibrium thermal model. this is transient 2D simulation. (a vertical column having porous material inside and top inlet for hot air and bottom outlet).
in start temperature distribution along the domain is fine and close to experimental values, but after 300 or 400 seconds temperature does not change or changes very little at all sections of domain and further it goes below the experimental values. I m using both fluid and solid properties as temperature dependent.
please guide me where i am doing wrong so I am not getting the uniform trend of temperature variation along the domain in whole simulation period.
please
Regards
mmunige is offline   Reply With Quote
Old   April 26, 2019, 04:45
Default je travail sur un profil rae2822 je vous faire une partie en souflage
harim
harim is on a distinguished road
bonjour
la partie soufflage je doit utilisé le cas porous et j'ai un problème dans les calcule les parèmetre merci de réponde
harim is offline   Reply With Quote
Multiphase flow & porous media Hisham OpenFOAM 3 April 10, 2011 07:04
Testing the integrity of POROUS media and por jump Azman FLUENT 0 July 31, 2006 11:11
porous media flow Siraj Siemens 4 February 24, 2006 22:24
Help :Porous media flow Wole CFX 7 August 30, 2001 20:32
Flow in Porous Media Q.Rosa CFX 1 March 13, 2000 10:45
