Rep Power: 13 ![]() |
The documentation says: The index number can be used with the FNODE macro to obtain the global face node number (e.g.,node = FNODE(f,t,n)). But this is not correct. I put this snippet in my udf: begin_f_loop(f, tf) { f_node_loop(f, tf, n) { v = F_NODE(f, tf, n); printf("The global node number is %i.\n",v); And I only get nonsense printed out. My entire domain has 4232 nodes, so I expect to see numbers on [1,4232] printed to the console. I have tried using *v instead of v, but I still get numbers that are in the range of billions, not between 1 and 4232. How can I get the actual node number from within a UDF? Thanks |
Lucky
Rep Power: 66 ![]() ![]() ![]() |
v is not a number but a reference to a Node dataclass. That's why it prints non-sense. You are seeing memory locations.
The local node number is actually n. I don't know how to get the global node number. |
I see. So when the manual says this is how to get the global node number, as I quoted, the manual is mistaken. That is awful.
Thanks for the reply. Maybe someone else will know how to do it. |
Lucky
I'm not saying all hope is lost. The local node number is n. My macro's are rusty. As first step, what happens if you do?
printf("The local node number is %i.\n",n); In serial cases that would be equivalent to the global node number anyway. In parallel cases, I don't recall how the threads are partitioned and how to collect them, or whether it is even necessary to collect them. |
Yeah, I do need the global node number, not just the local node. As I am using linear elements and looping over an edge, your code simply prints 1,2,1,2,1,2,1,2...
Ouyang
Rep Power: 8 ![]() |
Hi, ansys_matt! Hope you have solved this problem.
I also tried to obtain the global index number of node by udf just as you did, but failed. Thank you very much, ansys_matt! Last edited by eagle_001; May 21, 2019 at 21:48. |
decomposePar -allRegions | stru | OpenFOAM Pre-Processing | 2 | August 25, 2015 03:58 |
Compressor Simulation using rhoPimpleDyMFoam | Jetfire | OpenFOAM Running, Solving & CFD | 107 | December 9, 2014 13:38 |
999999 (../../src/mpsystem.c@1123):mpt_read: failed:errno = 11 | UDS_rambler | FLUENT | 2 | November 22, 2011 09:46 |
UDF Global Node Number ? | C. H. | FLUENT | 1 | November 24, 2006 10:02 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
