April 24, 2019, 05:21 |
Residuals oscillate every time-step
Manos Agra
Im running a centrifugal pump with a rotating levitated impeller pressure-based transient solution Model: SST-kw with pressure inlet and outlet impeller speed: 3000 rpm Methods: SIMPLE, PISO I have tried both SIMPLE and PISO with URFs reduced but my residuals keep osciliating in a every time step. Additionally the continuity is high. Even though the solution is converging im not sure about the quality of my results. The minumum orthogonal quality is 0.15 in a few cells and the majority is above 0.6. Attached a screenshot to take a glimpse. Any thoughts on how to reduce the continuity and skip the oscillation? Much appreciated, Manos |
April 24, 2019, 11:57 |
Lucky
Rep Power: 66 |
Where is the oscillation? It looks to be converging nicely.
Residuals will and should spike to very high values whenever a new time-step starts. You should get a saw-tooth looking like behavior, which I see here. It looks to me like you are doing 400 iteration per time-step. |
April 30, 2019, 10:38 |
#3 | |
Manos Agra
Thank you for your message and the information. Yeah is 400 iterations/time-step. I prolonged them now to converge. Do you think the continuity is abnormal? |
AMI speed performance | danny123 | OpenFOAM | 21 | October 24, 2020 04:13 |
time step continuity problem in VAWT simulation | lpz_michele | OpenFOAM Running, Solving & CFD | 5 | February 22, 2018 19:50 |
pimpleDyMFoam computation randomly stops | babapeti | OpenFOAM Running, Solving & CFD | 5 | January 24, 2018 05:28 |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 13:40 |
Star cd es-ice solver error | ernarasimman | STAR-CD | 2 | September 12, 2014 00:01 |
