May 18, 2014, 12:55 |
axial velocity definition
Ali reza
Rep Power: 12 |
hi everyone
I have a question about axial velocity in fluent specially in 3D curved pipes. It is an elbow which the velocity inlet is in X direction and I have got contour in X direction and it shows velocity correctly but in the same section I have got an axial velocity and it shows wrong contour and quantities I can't understand axial velocity and I don't know is it trustful or not? |
May 19, 2014, 07:46 |
A-A Azarafza
Rep Power: 14 |
It seems that you didn't define the axial direction correctly in your geometry modeler. I think, you should redefine the coordinate.
Regard yours |
May 19, 2014, 15:04 |
Behrooz Jamshidi
Rep Power: 13 |
For axisymmetric problems, in which the rotation axis must be the x axis, the x direction is the axial direction and the y direction is the radial direction. (If you model axisymmetric swirl, the swirl direction is the tangential direction.)
Axial velocity means the velocity in x direction in axisymmetric problems. So when your solver is not axisymmetric, axial velocity is meaningless (but sometimes has meaning!). Get your z-velocity contour. Is it the same as your axial velocity contour? |
May 19, 2014, 15:33 |
Ali reza
Rep Power: 12 |
thanks for support the velocity contour in z direction gives me just zero and I think at inlet I don't have any vector in z direction,
May 21, 2014, 19:10 |
#5 | |
Sean Delfel
Rep Power: 16 |
May 22, 2014, 14:00 |
Ali reza
Rep Power: 12 |
thanks for your support that's right but I don't know how to do that moreover the geometry was made by some pictures and I don't know all of angels and dimensions (it is 3d pipe that bends are not in the same plane) so finding axial velocity in each part by calculating the angels is some how needs great deal of effort.
December 16, 2016, 15:15 |
Axial and crossflow velocity!!!!!!
#7 | |
Ranjith Kumar J
Rep Power: 9 |
Which i later figured out that when you change x from 0 to 1 and change z from1 to 0 in cellzoneconditions tab would solve that problem!!!!! But now the problem is to find Crossflow velocity(perpendicular to axial velocity).Now i dont know whether crossflow velocity is the same as radial velocity or tangential velocity or neither of them.Please explain what the respective velocities mean actually? I also need to plot diiferent vector plots of crossflow velociitres at different sections? PLEASE HELP!!!!!!!!!! |
December 18, 2016, 11:38 |
Ranjith Kumar J
Rep Power: 9 |
CAN SOMEONE PLEASE HELP ME???????????
DESPERATELY NEED AN ANSWER.... |
January 28, 2017, 07:17 |
radial_velocity
#9 | |
SAIF MASOOD
fluentp1-1-02000.jpg t.jpg Last edited by saifmasood; January 28, 2017 at 07:18. Reason: forget |
April 30, 2019, 22:01 |
#10 | |
Ahmed
Rep Power: 7 |
You said that for axis symmetric problems, the rotation axis must be x-axis. Why is that? In my case, I am doing a simulation in Fluent with an axis symmetric rotating model with the axis of rotation in the y-direction. So, does that mean when I will go to plot velocity vectors (u, v, w) in Post processing, radial, axial and tangential velocity coressponds to u, v, and w respectively? For example, u=radial, v=axial and w=tangential. Or u and v become interchange? |
April 30, 2019, 22:57 |
#11 |
Behrooz Jamshidi
Rep Power: 13 |
The reason is that in documentation it has mentioned that axis boundary must be in x direction and also must not be in negative Y values. So you cant even start a simulation with axis boundary in Y direction. You should rotate your mesh by 90 degrees and do your simulation. |
May 1, 2019, 05:56 |
#12 | |
Ahmed
Rep Power: 7 |
May 1, 2019, 11:27 |
#13 | |
Lucky
Rep Power: 66 |
The axis boundary condition must be on the y=0 line. It's in the Fluent manual. The axial velocity is the velocity vector in a different basis. You can have the "axis" of this coordinate system be in any direction. You need not use an axis boundary condition when you want to reference your velocity as axial/radial/tangential system. You also need not use axial/radial/tangential system when you are using an axis boundary condition. You can use an axis boundary condition and stick to cartesian coordinates. |
axial velocity in tecplot | 1988 | Tecplot | 3 | March 24, 2014 16:48 |
Draw the tangential, axial and radial velocity for flow section | Al-Hashimi | FLUENT | 3 | August 12, 2013 01:16 |
Results of CFX Simulations | Sof_70_Usthb | CFX | 3 | July 9, 2011 06:15 |
Axial, Radial, Tangental velocity in FLUENT post | Barri | FLUENT | 2 | March 6, 2008 20:29 |
Radial Position and Axial Velocity Graph | Sal | FLUENT | 2 | August 1, 2007 09:29 |
