ignition failure with both gas phase and surface mechanism
Old   May 3, 2019, 11:14
Default ignition failure with both gas phase and surface mechanism
Weiqiang Liu
Weiqiang Liu is on a distinguished road
Hi all,
I am doing a methane catalytic combustion simulation with fluent. For now, I can simulate cases with only surface mechanism successfully. I am trying to include both gas phase and surface mechanism in my model.
gas mechanism in my model is SK16 (16 species and 43 reactions). Surface mechanism in my model is DETHCHEM (24 reactions)
since my case is steady state, I tried to ignite the mixture with two methods.
1. Patch 2000 k to the whole computation domain.
2. give an initial high temperature to the catalytic wall and calculate for hundreds of iterations. Then set back to coupled thermal condition.
My problem is I can not ignite the mixture. The whole process is like a heat conduction from the out wall to the whole domain. By the way, the thermal condition of out wall is set as constant temperature 773K.
I attached the temperature contour below.
Can anybody give me some suggestions? Or share some strategies regarding to how to ignite the mixture?
Best.
Weiqiang
Weiqiang Liu is offline   Reply With Quote
Old   May 3, 2019, 20:42
Weiqiang Liu
a lot of researchers have done similar research. anyone who's doing similar project?
gas mechanism, ignition., surface mechanism
Setting the height of the stream in the free channel kevinmccartin CFX 12 October 13, 2022 21:43
failure of ignition when using chemkin imported thermodynamic and transport data Weiqiang Liu FLUENT 1 February 11, 2019 19:30
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
[snappyHexMesh] Layers don't fully surround surface EVBUCF OpenFOAM Meshing & Mesh Conversion 14 August 20, 2012 04:31
gas phase and surface reactions Claud FLUENT 1 April 21, 2006 05:41
