NACA Airfoil simulation giving different lift coefficients in 2D vs 3D |
May 12, 2019, 13:04 |
Matthew Lam
Rep Power: 7 |
Hello everyone,
I am relatively new to CFD and ANSYS Fluent and have been trying to simulate flow of water at low Re (~50000 to 300000) around a 0.3 m chord NACA 0010 airfoil with an attack angle of 5 degrees to confirm the correct lift and drag coefficients. When I run a 2D simulation using the Spalart-Allmaras turbulence model I get values that correspond to the Xfoil Polars at http://airfoiltools.com/airfoil/deta...il=naca0008-il (Cd of 0.025 and Cl of 0.6) However, when I run a 3D simulation of the same airfoil extruded to a span of 0.5 m, the lift coefficient I get is much lower (Cl of about 0.2). The drag coefficient seems to stay accurate. I am pretty sure that the reference values I am using are correct: Area - 0.15 m^2 (0.3 m chord length x 0.5 m span) Velocity - 1 m/s (the same as the inlet boundary velocity) Density - 998 kg/m^3 I have tried refining the mesh and changing the size of the inflation layers next to the airfoil (I read somewhere that y+ can significantly affect accuracy), but so far I am having the same issue. If anybody could help, that would be much appreciated! Last edited by mrlam; May 14, 2019 at 09:20. |
May 13, 2019, 13:09 |
kia abdollahi makuyi
Rep Power: 7 |
Hi mrlam
I've done a similar simulation on NACA 4412 at a low Re (3e+4) and various angles of attack. I used k-kl-omega model which leads to pretty accurate results in low Re due to its transition prediction capability. I recommend to use this turbulence model. By the way, what is the grid y+ and what boundary conditions do you use? Could you attach a picture of your mesh? |
May 13, 2019, 19:06 |
#3 | |
Matthew Lam
Rep Power: 7 |
May 14, 2019, 06:00 |
#4 | |
Daniel Barreiro Clemente
Rep Power: 7 |
When you say Low Reynolds number, how low are they? Can you please specify the exact range of values? Thank you |
May 14, 2019, 09:19 |
Matthew Lam
Rep Power: 7 |
May 14, 2019, 09:37 |
#6 | |
Rep Power: 7 |
The turbulence model, as well as some of the key setup parameters are the following: -Airfoil length = 1m -Upstream domain size = 20 times the chords length -Downstream domain size = 40 times the chords length -Sides domain size = 15 times the chords length -Y+ value is <1. The number of cells from the airfoil wall to the end of the domain is 250, with an expansion ratio from the first cell of 1.05. It's an structured, streamwised mesh. -Number of cells: 240K The reported mesh quality in ICEM is very high as well. The Fluent setup is as follows: -Turbulence model: Transition SST -Inlet = velocity inlet with a defined speed corresponding to the desired Re number with respect to the airfoils chord -Outlet = pressure outlet -Coupled , Least Squares Cell Based ,Second order upwind, with reduced explicit relaxation factors to favour convergence -Convergence criteria = 10^-6 -Hybrid Initialization Would you mind sharing your setup and simulation parameters to see how they differ and if they would be a better fit for my simulation? How accurate are the lift and drag values you're obtaining? At the moment, for cases from 100,000 this setup works fine, with an average error of 5% for the lift coefficient and 15% for the drag coefficient, although I'm not fully satisfied with it. On the other hand, the results for the 60,000 are quite inconsistent and erroneous. Thanks in advance |
May 15, 2019, 09:33 |
#7 | |
Rep Power: 7 |
In the previous post I said that I've done the simulation in Re=3e+4 by mistake, it was 3e+5 similar to yours. |
May 16, 2019, 02:16 |
New South Wales
Rep Power: 10 |
Is the wing extruded through the whole domain (i.e. modelling an infinitely long span)? If it has a finite span, then getting lower C_L is normal - it will vary depending on your aspect ratio.
here is a good example: https://history.nasa.gov/SP-367/f56.htm |
May 16, 2019, 18:17 |
#9 | |
Matthew Lam
Rep Power: 7 |
I had no idea about this, in my case the aspect ratio is finite so that could definitely explain it. Thanks for your response. |
Need help for the 2D airfoil simulation using OpenFoam | losiola | OpenFOAM Running, Solving & CFD | 0 | October 10, 2018 10:22 |
How to not overwrite drag and lift coefficients after a simulation | Giovanni Trovato | FLUENT | 1 | August 1, 2018 00:31 |
problem numerical results of lift and drag in airfoil simulation using fluent solver | Mohammad1994 | FLUENT | 0 | June 7, 2018 02:59 |
Lift and drag coefficient with strange values for NACA airfoil | antonio_ing | OpenFOAM Running, Solving & CFD | 16 | September 13, 2012 12:21 |
Airfoil Simulation for Validation Purposes | Angela Bong | Main CFD Forum | 7 | September 13, 2006 13:04 |
