Pressure Far Field Boundary for low Mach Numbers |
May 14, 2019, 14:26 |
Horst van Gras
Rep Power: 7 |
Hi there,
ist there a minimum for the Mach number in pressure far field boundary condition? Because for Pressure 90000 and Mach 0.1 there is no chance for convergence. Increased quality and simplified the mesh but residuals won't decrese. By looking for residuals contours of velocity and turbulance modell, they are very high in the complete mesh, what I find doesn't make so much sense. With a badder mesh and Mach over 0.3 it's super easy converging. So is it possible that's I have to refine it so much to get the little compressible effects or is it just not possible with this boundary condition. Thx in advance! |
May 15, 2019, 15:05 |
Lucky
Rep Power: 66 |
There isn't a low mach number limit.
You have a general problem unrelated to the type of boundary condition. Maybe your initial condition is bad or your solver settings not tuned. But it's not because the boundary condition is not working. Whatever you are doing, you got lucky with the higher Mach numbers and unlucky with the super low Mach numbers. |
boundary condition, low mach flow, pressure far field |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 00:00 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
