May 18, 2019, 21:25 |
Pressure loss through a straight pipe
Surya Sarvajith
I have a straight pipe of 0.43" ID. I am trying to determine the pressure loss through a straight pipe of 1 m. I only know the Inlet pressure. I do not know the flow rate or the inlet velocity. I set my gauge pressure/Inlet pressure to 800 Psi. What should my outlet condition be? I tried setting it to outflow but I am getting reversed flow. What is a better boundary condition at the outlet?
May 18, 2019, 23:09 |
Rajesh
Rep Power: 8 |
Keep it as pressure outlet. Fluent will calculate the pressure at outlet.
May 19, 2019, 14:44 |
Lucky
Rep Power: 66 |
There's not enough info.
Knowing only the inlet pressure and pipe length doesn't define the problem. Any mass-flow rate, any pipe length, will satisfy this constraint. |
drop, fluent, loss, pressure, straight pipe |
Wind tunnel Boundary Conditions in Fluent | metmet | FLUENT | 6 | October 30, 2019 12:23 |
Sudden contration | MrAndersDk | OpenFOAM Running, Solving & CFD | 30 | October 11, 2018 03:23 |
pulsating static pressure around zero at pipe flow | David Kim | FLUENT | 0 | May 16, 2006 13:47 |
Pressure loss due to sudden expansion in pipe flow | Ahmed | FLUENT | 0 | January 2, 2006 10:01 |
Effects of gravity in pipe - pressure distribution | Anthony Wachs | FLUENT | 2 | July 25, 2001 07:07 |
