UDF library loading problem: parallel processing
Old   May 25, 2019, 02:30
Default UDF library loading problem: parallel processing
rishitosh's Avatar
Rishitosh Ranjan
rishitosh is on a distinguished road
Hii,
here is my udf used for calculating viscosity,
which shows following error on loading libudf:
UDF:
#include "udf.h"
#include "math.h"
#include "para.h"
DEFINE_PROPERTY(cell_viscosity,c,t)
#if !RP_HOST
real mu, A, B;
real mul=0.00113;
real fl=C_LIQF(c,t); //liquid fraction
real fs=1-fl; //solid fraction
real fscr=0.3;
if (fs> fscr)
A= 0.5-pow(M_PI,-1)*atan(100*(fs-fscr)); //14
B= (1-A*(fs/fscr));
mu= mul*pow(B,-2);
else
mu= mul;
#if RP_NODE
mu=PRF_GRSUM1(mu);
#endif /* RP_HOST */
return mu;
Massage after Compiling:
Copied E:\rranjan\Phd/E:\rranjan\Phd\prop.c to libudf\src
user_nt.udf file is outdated. So, recreating the file for 2ddp_host ...
(chdir "libudf\win64\2ddp_host")(system "copy "C:\PROGRA~1\ANSYSI~1\v192\fluent"\fluent19.2.0\sr c\udf\makefile_nt.udf "libudf\win64\2ddp_host\makefile" ")
1 file(s) copied.
(chdir "libudf")(chdir "win64\2ddp_host")# Generating ud_io1.h
user_nt.udf file is outdated. So, recreating the file for 2ddp_node ...
(chdir "libudf\win64\2ddp_node")(system "copy "C:\PROGRA~1\ANSYSI~1\v192\fluent"\fluent19.2.0\sr c\udf\makefile_nt.udf "libudf\win64\2ddp_node\makefile" ")
1 file(s) copied.
(chdir "libudf")(chdir "win64\2ddp_node")# Generating ud_io1.h
Done.
Massage after loading:
Opening library "E:\rranjan\Phd\libudf"...
Error at host: The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform (win64).
The system cannot find the file specified.
E:\rranjan\Phd\libudf\win64\2ddp_host\libudf.dll
Error at Node 0: The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform (win64).
E:\rranjan\Phd\libudf\win64\2ddp_node\libudf.dll
Error: The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform (win64).\n\nThe system cannot find the file specified.
\n\nE:\rranjan\Phd\libudf\win64\2ddp_host\libudf.d ll
Error Object: #f
can anybody help me in this regard.
with best regards,
Rishi.
rishitosh is offline   Reply With Quote
Old   May 26, 2019, 22:39
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
for this code you don't need parallel macros such as
#if RP_NODE
mu=PRF_GRSUM1(mu);
but your problem comes from other thing,
your code simply was not compiled. Make any change in code (print space and delete), than compile.
best regards
AlexanderZ is offline   Reply With Quote
problem with compiling boundary condition udf in parallel mode chem engineer Fluent UDF and Scheme Programming 11 June 29, 2015 06:23
Parallel UDF DEFINE_PROPERTY problem lehoanganh07 FLUENT 0 September 18, 2014 00:42
problem to make a UDF parallel pilou Fluent UDF and Scheme Programming 0 March 9, 2011 06:35
Parallel processing problem with Fluent Harish FLUENT 3 February 8, 2011 09:49
fluent UDF external library lapack problem Rick FLUENT 0 May 7, 2008 10:16
