June 11, 2019, 23:34 |
Velocity Magnitude for Steady state RANS
Rep Power: 8 |
While performing a steady state RANS CFD simulation with RNG k-ε turbulence model in Ansys Fluent, if I plot the velocity magnitude (V = SQRT(Ux^2 + Uy^2 + Uz^2) ) at a random point within the computational domain, does this velocity magnitude represents the mean and fluctuating velocity components or is it just representing the mean velocity at that particular point?
June 13, 2019, 10:30 |
Lucky
Rep Power: 66 |
only the mean
June 14, 2019, 05:31 |
Rep Power: 8 |
So, it means that as the instantaneous velocity "u" is split into mean velocity "U" and fluctuating velocity u' i.e., (u = U + u'), while time averaging over a sufficiently long time, say "T", the fluctuating component u' tends to zero and the time averaged mean velocity U is treated as a constant. So in short, while performing a steady state RANS simulation, the velocity magnitude plotted for a point or even on a contour tends to provide us only the mean velocity "U".
Is my interpretation of your statement correct? |
June 14, 2019, 12:08 |
#4 | |
Lucky
Rep Power: 66 |
Yes. The "velocity" that you get when you do RANS is only the mean velocity. RANS means Reynolds-averaged Navier Stokes. When you solve RANS, you are not solving the time-accurate Navier Stokes equations but the Reynolds-averaged ones, written in terms of the reynolds-averaged variables (which you are calling the time average velocity). If you do URANS (unsteady RANS) you still get unsteady reynolds-averaged, which is averaged over a finite T instead of infinite T. Here the velocity you get is still the reynolds-averaged velocity (containing no fluctuating part), although it does vary in time slowly. |
June 15, 2019, 00:11 |
#5 | |
Rep Power: 8 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
Simple piston movement in cylinder- fluid models | arun1994 | CFX | 4 | July 8, 2016 02:54 |
the mean of injection velocity magnitude and why wall film can't be used in steady? | sope111 | CFX | 0 | August 21, 2012 05:04 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 12:02 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
