Save case and data in a different folder using Journal |
June 14, 2019, 12:07 |
South Yorkshire
Rep Power: 7 |
I am running the same model multiple times, just changing one parameter (inlet velocity). I wrote different journals that change the velocity but I am having problems saving the data and case files in a different folder. That way, when I run the model next time it wont overwrite the files. Basically, I want to save the data, case, and output files (displacement) in a different folder. Thanks ! Regards, Daniel |
June 17, 2019, 02:45 |
Alexander
Rep Power: 34 |
make a loop and save your case/data files
(do ((i 1 (+ i 1)))((> i 3)) (ti-menu-load-string (format #f "file read-case \"YOU_CASE_FILE.cas\" OK \n" i)) (ti-menu-load-string (format #f "file write-data \"FULL_PATH_WITH_NAME_~a\" \n" i)) ) FULL_PATH_WITH_NAME_1 FULL_PATH_WITH_NAME_2 FULL_PATH_WITH_NAME_3 best regards |
fluent, tui |
[OpenFOAM] How to get the coordinates of velocity data at all cells and at all times | vidyadhar | ParaView | 9 | May 20, 2020 20:06 |
save case & data | Saman95 | FLUENT | 1 | August 12, 2018 06:09 |
save PARTICLE information in CASE and DATA | Alex | FLUENT | 1 | September 1, 2010 10:01 |
how to save case data and data during iteration? | JOHN | FLUENT | 3 | October 10, 2006 19:40 |
How to update polyPatchbs localPoints | liu | OpenFOAM Running, Solving & CFD | 6 | December 30, 2005 17:27 |
