June 18, 2019, 03:24 |
Separate cells by IsoSurface?
vidyadhar
Rep Power: 9 |
Is it possible to separate cells by an iso-surface of VOF=0.5? This iso-surface of VOF=0.5 divides each interface cell equally. So, I want to separate the fluid domain based on this iso-surface inorder to delete the fluid region on one side of this iso-surface. My fluid domain contains liquid with vapor above it. Thanks & Regards, vidyadhar |
June 18, 2019, 08:15 |
Deleting Vapor Cells from Fluent VOF simulation?
vidyadhar
Rep Power: 9 |
I have done VOF simulation using ANSYS Fluent. I have obtained an interface with liquid and vapor on either side of the it. I want to delete the vapor cells from the domain and make the interface as a WALL. I am marking cells with volume fraction from 0.5 to 1 and deleting them. When I try to do this, a zig-zag shaped WALL is forming instead of a smooth interface WALL. How to avoid zig-zag shaped WALL and to obtain a smooth interface WALL after deleting vapor cells? In literature: People have extracted images of the interface and bounding solid walls and meshed the volume containing liquid only. Even if someone suggest how to achieve this it would be great. Thanks in advance! vidyadhar Last edited by vidyadhar; June 23, 2019 at 02:16. Reason: added for more clarity |
vof phase change |
[snappyHexMesh] snappyHexMesh does not remove internal cells | Binglian Hu | OpenFOAM Meshing & Mesh Conversion | 16 | June 3, 2021 09:38 |
[snappyHexMesh] SHM Layer Addition Phase | dickcruz | OpenFOAM Meshing & Mesh Conversion | 4 | November 1, 2018 07:05 |
[snappyHexMesh] snappyHexMesh matches wrong cells to CellZone | Siegunn | OpenFOAM Meshing & Mesh Conversion | 4 | July 31, 2015 05:10 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
[snappyHexMesh] snappyHexMesh aborting | Tobi | OpenFOAM Meshing & Mesh Conversion | 0 | November 10, 2010 03:23 |
