July 25, 2019, 11:20 |
momentum source for mass source term
Weiqiang Liu
Rep Power: 9 |
Hi all,
I am doing a solid soot cake combustion with fluent. External soot mass is added into fluid because of reaction. Therefore I have mass source term in the model. My confusion is do I need to define momentum source for this mass source. Because I know generated mass source will be accelerated by cell averaged momentum. If I don't define momentum source for my mass source, velocity field would be different, right? If I need to define momentum source, how can I define this momentum source? My idea is : x Momentum source= mass source * cell volume* x velocity y Momentum source= mass source * cell volume* y velocity Am I right? Best regards Weiqiang |
C_UDSI_G use in momentum source term in eulerian model | Nishan | Fluent UDF and Scheme Programming | 1 | May 30, 2017 06:13 |
[Other] How to use finite area method in official OpenFOAM 2.2.0? | Detian Liu | OpenFOAM Meshing & Mesh Conversion | 4 | November 3, 2015 03:04 |
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 21:53 |
Trouble compiling utilities using source-built OpenFOAM | Artur | OpenFOAM Programming & Development | 14 | October 29, 2013 10:59 |
How does fluent handles the momentum source term? | QBeast | FLUENT | 0 | April 22, 2013 14:12 |
