July 27, 2019, 16:04 |
Thermal boundaray conditions
Edwin P
Rep Power: 8 |
I have a long duct opened at atmospheric pressure. I want to model a small section near to the end of the duct which generates heat. I have transient measurements of temperature at the beginning and at the end of the that section. At time t=0, all the system is at ambient temperature. Should I use both the inlet and oultlet temperature measurements of my sections as a boundary conditions in Ansys Fluent? Help me please, Regards Last edited by intied; July 27, 2019 at 16:05. Reason: typo error |
July 29, 2019, 00:48 |
Alexander
Rep Power: 34 |
from my point of view it depends on the goal of your simulation.
Make a decision -> what you want to simulate, then put boundary conditions best regards |
July 29, 2019, 01:52 |
Svetlana Tkachenko
Why is the temperature transient? Is this an externally imposed boundary condition in the experiment?
July 29, 2019, 10:53 |
#4 | |
Edwin P
Rep Power: 8 |
The temperature increase inside the duct is due to a solid with internal heat generation. I added a source term and I want to model its transient temperature profile |
July 29, 2019, 12:01 |
Lucky
Rep Power: 66 |
You can't impose an outlet temperature, not that you would need to, anyway. You would just use pressure outlet or outflow BC or something.
Just make sure you have the right inlet conditions and whatever else you need for your simulation. I can't follow what you want to do with heat generation and an inlet temperature. |
July 29, 2019, 15:18 |
#6 | |
Edwin P
Rep Power: 8 |
Thank you. In fact, I am using pressure inlet and pressure outlet as boundary conditions. But, I am not sure if I have to use the transient temperature profile in the "Thermal" tab of those boundary conditions. By other hand, I have a small solid which generates heat. I want to model its transient temperature. |
July 29, 2019, 18:25 |
Edwin P
Rep Power: 8 |
boundary conditions, temperature |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
Thermal Boundary conditions in natural convection problem | ekha | FLUENT | 1 | June 12, 2019 07:39 |
Question about adaptive timestepping | Guille1811 | CFX | 25 | November 12, 2017 17:38 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
