UDF of bubble departure diameter
Old   July 29, 2019, 11:03
Default UDF of bubble departure diameter
dxm2008 is on a distinguished road
Hello everybody
I have written a UDF for the Unal bubble departure diameter model, but it is still some problems. could you help me with that. the code is below:
#include "udf.h"
#include "stdio.h"
#define pi 3.1416
#define g 9.81
#define U0 0.61
DEFINE_BOILING_PROPERTY(bubble_depart_dia,f,t,c0,t 0,from_index,from_species_index,to_index,to_specie s_index)
int liq_phase = from_index;
int vap_phase = to_index;
Thread **pt0 = THREAD_SUB_THREADS(t0);
FILE *fp;
double a;
double b;
double phi;
double pre;
double dw;
double pre_op;
double rho_g;
double h_lg = 1.5038425e+6;
double rho_s;
double cp_s;
double k_s;
double T_wall;
double T_sat;
double T_l;
double rho_l;
double delta_Tsub;
double Ub;
T_sat = C_STORAGE_R(c0,t0,SV_SAT_TEMPERATURE);
T_wall = F_T(f, t);
rho_g = C_R(c0, pt0[vap_phase]);
rho_l = C_R(c0, pt0[liq_phase]);
rho_s = 8440.0;
cp_s = -5.0e-06*T_wall*T_wall+0.13123*T_wall+416.33;
k_s = -2.0e-05*T_wall*T_wall+0.052926*T_wall+1.6355;
a=(T_wall-T_sat)/(2.0*rho_g*h_lg)*sqrt(rho_s*cp_s*k_s/pi);
T_l = C_T(c0, pt0[liq_phase]);
delta_Tsub = T_sat-T_l;
if (delta_Tsub<=3.0)
b = delta_Tsub/(2.0*(1-rho_g/rho_l))*exp(delta_Tsub/3.0-1);
else
b = delta_Tsub/(2.0*(1-rho_g/rho_l));
Ub = C_U(c0,t0);
phi = MAX(pow(Ub/U0,0.47),1.0);
pre = C_P(c0, pt0[liq_phase]);
pre_op = RP_Get_Real("operating-pressure");
pre = (pre+pre_op);
if (b>0.0)
dw = 2.4145e-05*pow(pre,0.709)*a/sqrt(b*phi);
else
dw = 3.3216e-05*pow(pre,0.709)*a/sqrt(-b*phi);
return dw;
the calculated bubble departure diameter is too large and i don't know why. please give me some suggestion, thank you very much.
dxm2008 is offline   Reply With Quote
Old   July 29, 2019, 23:59
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
here you have space between t and 0, and between to_specie s_index
there should be no spaces, check it in your code
if this is not the reason of your problem, than check your equations,
because UDF code seems to be correct
best regards
AlexanderZ is offline   Reply With Quote
Old   July 30, 2019, 00:47
Originally Posted by AlexanderZ View Post
best regards
thank you for your reply, it may be the copy problem. In the UDF code, no space exist between t and 0, specie and s.
I want to know if the fluent has some modificaiton when using the Unal bubble departure diameter. or if I have some problem about unit?
Old   July 31, 2019, 23:24
Originally Posted by dxm2008 View Post
Hello everybody
#include "udf.h"
#include "stdio.h"
#define pi 3.1416
#define g 9.81
#define U0 0.61
FILE *fp;
double a;
double b;
double phi;
double pre;
double dw;
double pre_op;
double rho_g;
double rho_s;
double cp_s;
double k_s;
double T_wall;
double T_sat;
double T_l;
double rho_l;
double delta_Tsub;
double Ub;
T_wall = F_T(f, t);
rho_s = 8440.0;
else
Ub = C_U(c0,t0);
pre = (pre+pre_op);
if (b>0.0)
else
return dw;
Hello everybody
the reason maybe these lines
else
in the Unal's original paper, the subcooling is requested to be larger than 3K. in the Fluent, a modificaiton is used in the calculation of b. so when delta_Tsub is close to 0, b suffer a large fluctuation which lead to a large bubble departure diameter.
but if anyone knows how is dealed with in the fluent calculation without UDF?
udf, unal
Bubble column simulation with Lift coefficient UDF raju.vadlakonda Fluent UDF and Scheme Programming 8 June 19, 2023 08:36
UDF bubble diameter CeesH Fluent UDF and Scheme Programming 9 May 20, 2023 02:54
bubble equivalent diameter mayj CFX 9 November 17, 2019 12:12
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Query on VOF for Bubble rise Vamsi Main CFD Forum 0 December 22, 2005 00:02
