Transition SST on laminar flow?
Like Tree1Likes
  • 1 Post By TU_Hiwi
Old   August 6, 2019, 16:13
Default Transition SST on laminar flow?
Lukas
TU_Hiwi is on a distinguished road
Hey Guys,
I am currently modelling a case where I suspect the flow to be laminar but I am not sure since it a complex geometry. Since applying a turbulence model when there is no turbulence to model has an (negative) impact on the results, I thought it should be safe to use the transition SST since its capable of modelling both, laminar and turbulent.
Is this a wrong guess? Any hits, tricks or literature tips?
Greetings Lukas
Светлана likes this.
TU_Hiwi is offline   Reply With Quote
Old   August 6, 2019, 20:07
Svetlana Tkachenko
Светлана is on a distinguished road
Did you do a mesh independence study?
How do you define "negative impact on the results"?
Светлана is offline   Reply With Quote
Old   August 7, 2019, 04:12
Lukas
I did an independency study using the sst model.
A negative impact would be generated turbulence where none should be or falsified transport of species.
Another question: do i need any kind of Walltreatment in a laminar flow?
Old   August 14, 2019, 11:01
MIDHUN
MIDHUN@CFD is on a distinguished road
Send a message via Skype™ to MIDHUN@CFD
can you specify the Re at different locations and give a screenshot of the geom
MIDHUN@CFD is offline   Reply With Quote
Old   August 14, 2019, 11:11
Lukas
there will be really low Re, 1E-4 for a cylinder, so i am assuming its laminar.
I changed the inlet turbulence and the flow fields turbulence totaly depended on that inlet turbulence. In other words: there was nearly now generation of turbulence inside my model.
Greetings
Old   August 14, 2019, 11:42
MIDHUN
why dont you solve with laminar model then ?
Old   August 14, 2019, 14:02
Lukas
That is what i also thought after calculating the Re. But still, if i am using a turbulence model, inlet turbulence is zero, is it the same as modelling laminar?
Greetings
Old   August 14, 2019, 14:06
MIDHUN
use laminar and try .. what is the maximum diameter ? less than 1 mm?
Old   August 14, 2019, 14:11
Lukas
the Diameter is 160E-6 m = 160 \mu m, v_in from 0,0075 m/s to 0,1 m/s
Old   August 14, 2019, 14:19
MIDHUN
it will be laminar flow .. try laminar only .. if u need any furthe assitance contact me midhun6189@gmail.com
Predict Flow transition surajp92 STAR-CCM+ 1 September 20, 2017 14:08
Optimize for laminar flow, assume it valid for turbulent flow? Chander CFX 15 November 6, 2011 05:06
Code release: Flow Transition and Turbulence Chaoqun Liu Main CFD Forum 0 September 26, 2008 17:15
Validation for laminar Disperse phase flow shashwat Main CFD Forum 0 April 4, 2008 02:20
Swirling flow in a diffuser: K-E over SST ? Felix CFX 3 February 27, 2007 21:03
