Annular flow system doesn't converge
Old   August 8, 2019, 05:05
Default Annular flow system doesn't converge
bumper is on a distinguished road
Hello everybody,
I'm doing a simulation of the flow in an annular gap. The inner cylinder is modelled as a rotating wall and the outer one is a stationary wall. The left and right side are stationary walls as well. All in all, it is a closed system. I'm using the realizable k-epsilon model with enhanced wall treatment.
For the convergence, the resiudals should fall by a magnitude of [LaTeX Error: Syntax error] respectively [LaTeX Error: Syntax error]. I do a steady state simulation with 2000 iterations. But i don't reach the values to say, that my system is converged (please see the attached picture). What can i do for reaching a converging system?
Please tell me, if you need additonal information.
Thanks for your help,
bumper
bumper is offline   Reply With Quote
Old   August 14, 2019, 09:51
MIDHUN
MIDHUN@CFD is on a distinguished road
Send a message via Skype™ to MIDHUN@CFD
what is your wall y plus , did you try sst k omega model? realizable is not cpmpatinle with mrf/rotating boundary
MIDHUN@CFD is offline   Reply With Quote
Review: Reversed flow CRT FLUENT 1 May 7, 2018 05:36
Piece-wise compressible flow in pipe system jabier14 FLUENT 1 March 2, 2017 15:00
Annular Flow Using VOF TedBrogan FLUENT 4 January 1, 2016 04:31
Converge problem for unsteady gas solid flow kongl1986 FLUENT 5 March 1, 2012 16:31
annular flow domain mshannag ANSYS Meshing & Geometry 1 May 2, 2011 03:05
