negative volume error in dynamic mesh
Like Tree2Likes
  • 1 Post By MIDHUN@CFD
  • 1 Post By krishna.n
Old   August 13, 2019, 09:21
Post negative volume error in dynamic mesh
amdfzn
amdfzn is on a distinguished road
Hi All
I want to simulate a simple movement of a cube (which represents a human) in a room using dynamic mesh. I used tetrahedral elements for all of the domain and also smoothing and remeshing methods for updating the mesh and defined the surfaces of the cube as rigid body zone. After some time (about 0.1 to 0.2 s), negative volume error occurs. I tried to reduce the time step and also changed different parameters in dynamic mesh settings but none of them works and I still get the negative volume error. Can someone help me with that please?
amdfzn is offline   Reply With Quote
Old   August 13, 2019, 12:58
MIDHUN
MIDHUN@CFD is on a distinguished road
Send a message via Skype™ to MIDHUN@CFD
can u send the wb file to midhun6189@gmail.com if you are using version less than 19.1
amdfzn likes this.
MIDHUN@CFD is offline   Reply With Quote
Old   August 14, 2019, 00:56
KcN
krishna.n is on a distinguished road
Originally Posted by amdfzn View Post
Hi All
Sometimes negative cell volume is where the mesh is overlapping. Try changing the skewness in dynamic mesh or reduce the time step.
amdfzn likes this.
krishna.n is offline   Reply With Quote
Old   August 14, 2019, 02:39
amdfzn
Originally Posted by krishna.n View Post
Hi krishna,
I changed the face skewness to 0.4 and cell skewness to 0.7 and also reduced the time step but I still get the error.
Old   August 16, 2019, 07:52
KcN
Hi krishna,
Initially, try giving default skewness values.
dynamic mesh, negative volume error
[blockMesh] blockMesh error - Negative Volume Block adoledin OpenFOAM Meshing & Mesh Conversion 2 June 22, 2016 10:44
Problem of simulating of small droplet with radius of 2mm liguifan OpenFOAM Running, Solving & CFD 5 June 3, 2014 02:53
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 05:42
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 21:14
