Convergence issue with moving surface
Old   August 30, 2019, 03:06
Default Convergence issue with moving surface
Prasun Dutta
pd.iiest is on a distinguished road
I am facing a convergence issue with the continuity equation in my simulation. I am using a laminar model (Re = 100) for jet impingement on a moving surface. I am not facing this issue with fixed surface or surface movement at low speed. This happens only for if the surface movement velocity is equal or higher than the impinging jet velocity. For these cases, in the starting of simulation, residuals continuity equation start with usual convergence pattern but after some times it diverges. I am attaching a screenshot for better understanding. I have refined the mesh and run several grid tests but the issue remains.
Thanks in adv.
pd.iiest is offline   Reply With Quote
continuity equation, convergence issue, jet impingement, moving surface
[snappyHexMesh] Surface triangulation using snappyHexMesh shaileshbg OpenFOAM Meshing & Mesh Conversion 4 October 17, 2019 04:42
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
CFX convergence issues with free surface adenlan CFX 3 September 2, 2011 06:43
Free surface and moving body Steve Siemens 4 August 20, 2004 11:06
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
