September 6, 2019, 09:11 |
Incompressible ideal gas
Rep Power: 7 |
I’m working in a natural convection flow, I would like to know using the incompressible in the ideal gas flow how can it affects the Navier-stokes equations? . Another question, which solver (segregated/coupled) should I use for natural convection of incompressible ideal gas and for normal ideal gas?.
September 6, 2019, 13:58 |
Lucky
Rep Power: 66 |
The density in the incompressible ideal gas is taken at the operating pressure and doesn't change with pressure.
Both solvers work. |
September 6, 2019, 15:20 |
#3 | |
Rep Power: 7 |
I have a question why in the incompressible ideal gas the governing equations can be decoupled but they can’t in the ideal gas?. |
September 8, 2019, 03:24 |
Lucky
Rep Power: 66 |
The equations are coupled. How to solve a system of coupled equations is another matter. You can take a divide-and-conquer approach (the segregated approach) or you can try to figure out a way to solve the coupled system.
September 8, 2019, 06:33 |
Rep Power: 7 |
How can we solve it using segregated approach if they depend on each other?.sorry i’m getting lost
September 8, 2019, 20:27 |
#6 | |
Lucky
Rep Power: 66 |
Let's say you have a temperature-based formulation for energy. So the variables you're solving for are density, pressure&velocity, and temperature. In the segregated approach, you could assume a background temperature field (by taking the latest guess) and then solve the continuity and momentum equations for an updated density, velocity, and pressure. Then you take your newest density, velocity, and pressure, and solve the energy equation for a new temperature field. Voila, you've solved a coupled system of equations using a segregated approach. |
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 21:43 |
Domain Reference Pressure and mass flow inlet boundary | AdidaKK | CFX | 75 | August 20, 2018 05:37 |
Difference between Ideal gas and Incompressible Ideal gas law | kr660170 | FLUENT | 2 | July 3, 2018 02:13 |
Incompressible converges, ideal gas goes nuts | psigcochair | FLUENT | 3 | January 14, 2010 20:14 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 12:02 |
