November 4, 2019, 10:00 |
Reference area of 2D axisymmetric geometry
Shashwat
Rep Power: 6 |
I am doing a drag analysis of rocket nose cone and I want to use 2D geometry instead of 3D geometry to save time. I know I have to use a 2D geometry with axisymmetric but how can I find the reference area for the geometry. In 3D we can find the reference area using projected area but how to find for 2D axisymmetric body.
November 4, 2019, 10:15 |
Lucky
Rep Power: 66 |
In 2D, the pressures are integrated over the reference depth (default is 1 m), which is another needed input. Now you have a force that acts over an area.
Hint: you can imagine your 2D body being extruded 1m in the third direction and treat it as a 3D body. This analogue doesn't always work because the reference depth need not be 1m and the reference area need not be the projected area. |
November 5, 2019, 00:19 |
#3 | |
Shashwat
Rep Power: 6 |
I understand what you are saying but what you are telling is applicable for planar surface like an aerofoil. But nose cone is a revolving surface so can we take reference depth of 1m in 3rd direction? Or do we need to revolve the surface 360 degrees and then find the projected area? (In this case, I know that reference area is projected area) |
November 5, 2019, 02:21 |
Lucky
Rep Power: 66 |
I missed the part where you mentioned a cone.
In that case, it's integrated over 1 radian |
November 5, 2019, 06:12 |
Shashwat
Rep Power: 6 |
February 16, 2022, 08:25 |
#6 | |
sina
Rep Power: 4 |
I want to compute area in 2D axisymmetric. Do you figure out how can we compute it? Could you please share it? Best Regards, |
February 16, 2022, 12:27 |
Lucky
Rep Power: 66 |
The reference area comes from the 3D representation of the object unless you have a degenerate body such infinite parallel plates where there is no meaning of area.
The pressure being integrated over 1 radian is related to how you go about computing reference area except to understand how the coefficients are calculated using a surface integrated force in 2D. If you are doing a 2D axissymmetric simulation of a cone, draw the 3D version of the one and get the reference area. |
February 16, 2022, 12:40 |
#8 | |
sina
Rep Power: 4 |
bottom of geometry is axis. Last edited by sina_sls; February 16, 2022 at 14:33. |
axisymmetric 2d fluent, drag coeffcients, reference area |
compile error about FJMPI | chiven | OpenFOAM Installation | 11 | March 31, 2010 06:27 |
Axisymmetric Reference Area | jack1980 | FLUENT | 0 | October 16, 2009 09:34 |
G95 + CGNS | Bruno | Main CFD Forum | 1 | January 30, 2007 00:34 |
Building OpenFoAm on SGI Altix 64bits | anne | OpenFOAM Installation | 8 | June 15, 2006 09:27 |
