November 12, 2019, 06:15 |
How to make Rotating Ball?
WooHyeong Lee
Rep Power: 6 |
Hi, I'm really really new student who is recently learning fluent in south korea.
I wanna simulate the 3D rotating ball in fluent. In class I always learned only static golf ball. I mean the ball doesn't rotate. But I want to rotate the ball while the program calculating. Would you please help me how to do that? or give me some practical link. Thank you very much. |
November 12, 2019, 11:29 |
Lucky
Rep Power: 66 |
You can jut use a moving wall by giving the wall a velocity. Normally the walls do not move (with a velocity of 0 m/s), but you can apply any number. Everything else is the same as a static ball.
November 12, 2019, 11:41 |
Joshua
Rep Power: 11 |
There are several possible approaches.
November 12, 2019, 23:58 |
#4 | |
WooHyeong Lee
Rep Power: 6 |
I have one more question. I made a ball and enclosure and then used boolean to subtract and finally i made it as 1 body For apply case 1, Do I have to make a ball and fluid way for 2 body?? Sorry for my poor explanation. Thank you. |
November 13, 2019, 00:06 |
Joshua
Rep Power: 11 |
I don't really understand your question, but if you have a single conformally meshed domain, you can change the wall motion settings for the ball. See the attached pic (note its from a 2D setup, not 3D).
Determine the center of rotation, specify the axis of rotation, and a rotational velocity. wallbc.PNG |
November 13, 2019, 11:45 |
Lucky
Rep Power: 66 |
You don't mesh the ball. There's no flow inside the ball, you are doing CFD. You only mesh the ball if you want to model other stuff happening in the ball. All you need is the spherical wall surface which contains all the interaction between the flow and the ball. I.e. draw a control volume for just the fluid.
[openSmoke] libOpenSMOKE | Tobi | OpenFOAM Community Contributions | 562 | January 25, 2023 09:21 |
Quick question - Can I use rotating wall for a spinning rugby ball (with seams)?? | Rake32 | FLUENT | 5 | March 1, 2017 14:24 |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 13:41 |
rotating ball in water | Aliz | Main CFD Forum | 0 | February 21, 2011 03:43 |
Simulates the rotating ball | nvtrieu | Siemens | 3 | July 6, 2009 15:12 |
