March 29, 2018, 06:53 |
Average torque in transient vawt simulation
Patryk
Rep Power: 10 |
Dear users,
I'm simulating flow around 3 blades, vertical axis wind turbine (2D) for my master thesis using sliding mesh method. I have done 200 timesteps with 0,005s time step size which give 5s of real time simulation. My results looks really fine, but I need to know average torque over rotation axis (Z) on all blades of the turbine in that 5 seconds and I don't know how to calculate it. Value of torque is different in every timestep. Is it possible to export torque from all timesteps to excel and then calculate average of it ? I tried to plot Momentum during the simulation (Solution -> Report Definitions -> Force Report -> Moment), and than select blades and Z axis, but values on that plot is always less than 1, so it looks like Cm, not really torque. When i calculate torque using CFD-Post calculator the values at any timestep looks fine. Thanks for help. Sorry for my english.. |
March 30, 2018, 08:33 |
Patryk
Rep Power: 10 |
Please help. I'm stuck here because I can't compare my cases
March 31, 2018, 12:04 |
Patryk
Rep Power: 10 |
Ok, problem solved.. if anybody else facing it, there is a solution :
You need to print a Cm plot (like I wrote in 1st post) and write this values to a file. Then export this file to excel and count torque using this formula for every timestep : where M - torque, V - stream velocity, A - Area, L - lenght (rho, A, L in 'reference Value tab') Finally, just do the average of all torque values. |
December 20, 2019, 12:03 |
Nguyễn Tài Đức
dear feveR
I am simulating a VAWT like you. Can I ask some question about moment and moment coefficient When you set up the solution, did you set the reference value? what reference values you set? I set Area = wing area, lenght = radius, velocity = wind speed the moment coefficient is very low according to my calculations. hope you share your experience thank you |
2d simulation, average, torque, transient, vawt |
y+ and u+ values with low-Re RANS turbulence models: utility + testcase | florian_krause | OpenFOAM | 114 | August 23, 2023 06:37 |
VAWT simulation rotation domain | steve20024 | Main CFD Forum | 0 | March 2, 2015 04:37 |
Steady Simulation of VAWT | steve20024 | Main CFD Forum | 4 | November 27, 2014 06:02 |
Resume Transient simulation | HMR | CFX | 1 | June 28, 2011 22:13 |
How obtain the average of lift over time for a transient simulation? | aero | ANSYS | 0 | November 11, 2009 03:00 |
