January 15, 2020, 04:25 |
Rectangular box with round inlet in 2D?
until now, i´ve done durability and stiffness simulations, so CFD is new to me. Now i have to do a 2D simulation of a rectangular box with an internal round velocity inlet (see attached graphic). The pipe of the inlet can be ignored in the simulation. So if you look from the side in 2D, there is just an edge left for the inlet. So far so good. But in my opinion this problem could not be solved in 2D, because there are not uniform shapes in the depth, because of the rectangular form of the box. Or how should i set up this problem? Thanks a lot and greetings, Flow_Newbie |
January 15, 2020, 17:20 |
Lucky
Rep Power: 66 |
What is your objective?
Both pictures are simulate-able (sort of) and you'll be able to infer different things. I say sort of, because you have an inlet but no outlet... You might want to fix that first. |
January 15, 2020, 18:35 |
The objective is to show the velocity distribution in y-direction. The picture is just a simple sketch, in the real model there is a pressure outlet in the middle of the box bottom.
I've already simulated this problem, with the simple solver and the k-epsilon turbulence Modell. My problem is, that I don't think that the results are correct. In 3D can the air circulate around the nozzle in all directions and dimensions. But in 2D there is no depth (just the 1m per default) or everything has the same depth, also box and nozzle. That would mean that the nozzle go through the whole way from the front to the back of the virtual depth?! But in real that is not the fact, the nozzle is just a small circle in the middle of the box. How can I get anyway the right velocity distribution? I hope my problem and my thoughts are understandable. |
January 16, 2020, 10:04 |
Lucky
Rep Power: 66 |
Well a 2D model isn't a 3D model. That's why I ask what is the objective.
You can infer a lot of things still, depends on what your goal is. If you think it's wrong, then do a 3D one. |
multiphaseInterfoam non-constant inlet | kaaja | OpenFOAM Running, Solving & CFD | 4 | February 23, 2018 02:04 |
massflow inlet on cooling plate definition inside the ambient air box | farianka | FLUENT | 0 | March 21, 2017 06:27 |
[ICEM] Multi-Block Meshing of a Rectangular channel with inlet at 90 deg | khedar | ANSYS Meshing & Geometry | 0 | October 15, 2016 14:56 |
Reusing the inlet time directories in timeVaryingMappedFixedValue | ngj_22 | OpenFOAM Running, Solving & CFD | 0 | January 24, 2013 10:22 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
