Methane Combustion
Like Tree4Likes
Old   February 5, 2020, 10:43
Default Convergence check
  #21
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
I would recommend not to look at the residuals for convergence. As long as those are smaller than 1, they are OK. Look at some of the monitors, such as the pressure monitors you have setup. Furthermore, if the monitors are setup for a vertex, these will oscillate as well. Standard practice is to monitor area-weighted or mass-weighted averages over boundaries. If these settle down to plausible, constant values, then simulation is numerically converged.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   March 14, 2020, 09:20
Lee Jo
the_sixth_hokage is on a distinguished road
Originally Posted by Biagio View Post
Hi, i-m simulating LOx-CH4 Combustion in supercritical condition. I'm using real gas Soave Redlich Kwong equation of state and Eddy Dissipation model dfor the combustion, and i'm struggling with this error: Temperature is below the spinodal point in xxx cells", has anyone ever experienced this? Any solution?
hey...I am also doing the same simulation (Test case G2) and hope you could shed some light on some problems I'm facing...
I am using
- a 4 step Jones-Lindstedt mechanism and Grimech 3.0 Thermo
and Transport files..
- EDC model with k-epsilon and srk equations..
I am also facing liquid solution only possible error and dasac failure at temperature= xxxx... errors
Hope you see this... Can you give some tips on solving this test case G2...
the_sixth_hokage is offline   Reply With Quote
Old   March 14, 2020, 10:59
Default DASAC Failure
  #23
vinerm's Avatar
Vinerm
DASAC is an ode solver that directly integrates the chemical source term over time. It can show failure in the beginning if the initialization is not very good, however, it should improve as the simulation proceeds. However, if Fluent keeps on showing the error, then it could be due to any reason ranging from bad initialization to material properties or reaction mechanism. Since specific heat is very important for calculation of enthalpy values, if it is given as a UDF or some function, do check that it is compatible with enthalpy calculation, otherwise, this may lead to failure of source term integration. You mentioned GRI Mechanism, however, if you are using GRI Mechanism for reactions kinetics and species as well, do check the units in the file.
Furthermore, you may try with Chemistry Agglomeration. This has potential to improve the situation.
Regards,
Vinerm
Old   March 14, 2020, 12:18
Lee Jo
what monitor should I use to monitor the convegence in combustion flows... I am not using any udfs for specific heat..im using the polynomial fit from thermo files..
Old   March 14, 2020, 12:49
Default Convergence
  #25
vinerm's Avatar
Vinerm
Ensure that the coefficients for the C_p polynomial are correct.
As far as monitoring is concerned, you may monitor temperature or enthalpy and mass fractions of species.
the_sixth_hokage likes this.
Regards,
Vinerm
Old   March 15, 2020, 01:12
Lee Jo
I have check the units of in chem.out file and was same as the given units in input file...
The chemistry agglomeration made the simulation faster...
The errors I'm currently getting are:
Mass_diffusivity: invalid (zero) diffusivity
Divergence detected in AMG solver: temperature
Divergence detected in AMG solver: epsilon
Divergence detected in AMG solver: species-0
Divergence detected in AMG solver: speices-1....etc
WARNING: Invalid cp (0.000000e+00 J/kgK ) for chemkin import at temperature 2370.470703 K
Will the grimech 3.0 Thermo polynomials be enough or should I create one for myself at 5.6Mpa pressure using data from NIST...
Old   March 15, 2020, 03:32
Default Polynomial Coefficients
  #27
vinerm's Avatar
Vinerm
You should check the accuracy of polynomial coefficients by plotting it over the whole temperature range. As you observed, Fluent is calculating 0 value for a certain temperature. This implies there is something wrong with the polynomials. Use any plotting tool and plot polynomial with the given coefficients over the temperature range, ranging from 1 K to at least 5000 K. Sometimes the polynomial is not valid outside a certain range; this would be given within the database.
Regards,
Vinerm
Old   March 15, 2020, 04:40
Lee Jo
I can get data from NIST database for my operating pressure (5.6 MPa) and using some curve fitting tool I can generate polynomials...but I don't know how to implement these into Fluent....I tried to change the default coefficient values and tried it...but I ran into some errors and crashed...not sure whether I did it correct...
Old   March 15, 2020, 15:23
Default Coefficients
  #29
vinerm's Avatar
Vinerm
Before changing the coefficients, do check their validity by plotting. The plot doesn't have to be continuous but valid over the range being used. If the mixture or specie is using thermodynamic database for specific heat, then you have to go through the CHEMKIN manual for understanding the format of thermo.db to change it.
Regards,
Vinerm
combustion, methane, oxygen, supercritical
mechanism for non-premixed methane air combustion a.Asadi OpenFOAM Running, Solving & CFD 7 October 14, 2016 16:02
FSD combustion model with a mixture of methane and hydrogen for fuel babakflame OpenFOAM Running, Solving & CFD 0 January 14, 2014 11:56
How to model combustion with only methane stream? ligang zheng FLUENT 2 May 1, 2007 09:16
Methane combustion in gas burner Stefano CFX 1 June 7, 2005 02:12
Methane Combustion Lars FLUENT 4 March 5, 2003 08:24
