Aerodynamic optimization : how to eliminate stalling wings ? |
February 10, 2020, 09:23 |
Rep Power: 6 |
Hi guys,
I'm actually working on the optimization of a leading edge of a morphing airfoil (single-element airfoil). This optimization is done by varying its geometry for an angle of attack higher than the stall angle and therefore, some of the airfoils you get lead to stall. However, once the stall is reached, value of the lift coefficient oscillates (i.e. RANS simulations of the airfoil don't converge) and sometimes, once the maximal iterations number is reached, the simulation stops while the lift coefficient is the highest. Consequently Ansys thinks that this kind of design points are good … But they are not ! I can't find a way to "eliminate" those airfoils in the optimizer. I already tried to use an average lift coefficient but Ansys doesn't accept it as an output parameter. I also thought about using residuals as output parameters (and eliminate airfoils for which residuals are above a certain limit) but I can't find a way to do this. Can someone help me ? Thomas. |
February 10, 2020, 10:10 |
Which optimizer
You didn't mention which optimizer is being used; is it the optimization tool within the Fluent or is it based on DOE in the WB?
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
February 10, 2020, 10:24 |
Rep Power: 6 |
February 11, 2020, 04:06 |
Apologies
No experience in WB
ansys, fluent, optimization, residuals, stall |
MOGA Direct Optimization | chris15012 | ANSYS | 0 | February 17, 2019 14:55 |
Best surrogate model for aerodynamic optimization | freebird | Main CFD Forum | 0 | June 30, 2018 18:13 |
SQP method for adjoint based aerodynamic shape optimization | cfdbooks | Main CFD Forum | 2 | May 26, 2009 10:40 |
Inverse design and Optimization of Aircraft Wings | Simon Nava | Main CFD Forum | 8 | May 22, 2007 14:55 |
Aerodynamic Optimization | Chan | Main CFD Forum | 5 | July 16, 2003 13:46 |
