March 13, 2020, 04:46 |
Residuals-Ccontinuity
Elif Gündoğdu
Hello dear all,
I am a newbie using ANSYS Fluent. I have a 3D model which's inlet is velocity inlet and outlet is is pressure outlet. I tried to solve it for three different mesh models and for each I got different solutions. I enter all values same, only mesh is different. I am also employing a formula, so it is interesting that the one with more fluctuations in continuity residual gets closer to the formula output. I am attaching residuals to this thread, I would be really happy if anyone let me know which one is more correct. Thank you beforehand. 61FAFF94-35E8-45EA-AD3E-605A841B518D.jpg CA95B243-2070-4B51-BBC1-6D1D4046AD96.jpg E3F17C95-AD66-431C-85FA-AC7E2636CE7F.jpg |
March 13, 2020, 05:35 |
Residuals
Residuals alone are not good indicators of convergence. You have to monitor some other quantity, such as pressure at inlet, to measure convergence.
Convergence does not imply accuracy, only that the field is converged for a given set of conditions. So, better would be to set a few monitors in all cases and then observe how much do they change over iterations and from case to case.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
New residuals function type in OF 2.4.0 not known | Babis | OpenFOAM Post-Processing | 2 | June 11, 2015 13:27 |
plot residuals | pigna | OpenFOAM Running, Solving & CFD | 2 | December 19, 2014 02:32 |
motorBike Residuals for SST k-omega... and mine | JR22 | OpenFOAM Running, Solving & CFD | 6 | August 1, 2013 09:08 |
judging convergence through residuals | MachZero | Main CFD Forum | 7 | December 25, 2012 12:18 |
Convergence - scaled vs unscaled residuals | HS | FLUENT | 1 | November 7, 2005 05:45 |
