r.m.s velocities calculation after sampled LES |
April 1, 2020, 10:43 |
Akram
Rep Power: 9 |
Hello everyone
I've run LES case, I did data sampling, but I cannot find how to display or calculate axial r.m.s velocity u', only RMSE values are available. Does anyone know what formula should I use to find rms velocities values Thank you |
April 2, 2020, 00:11 |
Lucky
Rep Power: 66 |
The RMSE of u is equivalent to the RMS of u' because the mean of u' is 0.
April 3, 2020, 01:58 |
Akram
Rep Power: 9 |
Thank you LuckyTran for your reply, and I appreciate if you guide me to any reference telling this in fluent theory guide or elsewhere
April 3, 2020, 13:56 |
Lucky
Rep Power: 66 |
It is verrry trivial. Just read up on RMS and RMSE
Note that the fluctuation velocity u' is the velocity u(t) with the mean subtracted out. People often mistakenly call u' the RMS velocity, which can add to the confusion. The hint is that the RMSE of u' and the RMS of u' are the same. The mean of u' is 0. The RMS of the mean of a quantity is the same as the mean. |
April 5, 2020, 13:23 |
Akram
Rep Power: 9 |
Yes that's true, just got confused from some posts saying random things
.. anyway, thanks again |
LES Filtering: how are the small and large scales equations solved? | atmcfd | Main CFD Forum | 38 | March 14, 2016 14:52 |
Transient Statistics for LES | Sungho Yoon | CFX | 0 | August 4, 2008 11:12 |
why in the les calculation, need turbul intensity? | aiya | FLUENT | 0 | June 27, 2006 12:30 |
Differences between a laminar code and a les one | ben | Main CFD Forum | 9 | February 16, 2005 23:40 |
Averaging Method for LES | Kim | Main CFD Forum | 0 | November 21, 2001 07:18 |
