April 30, 2020, 04:09 |
Heating value of Methane in Fluent
Arvind Jay
Rep Power: 14 |
Hello.
In my non-premixed combustion problem, I would like to burn 30000 BTU/hr of methane sent from the gas inlet. In order to impose the corresponding mass flow of methane, I need two parameters. Firstly, the inlet gas temperature, that would dictate the gas density and secondly, the heating value of methane. Could anyone let me know, where this heating value is specified in Fluent. Is it computed from the standard enthalpy of methane? Could you explain how we can deduce the heating value from the standard enthalpy? Thanks, Jay |
April 30, 2020, 05:33 |
Heating Value
Yes, it is calculated from standard state enthalpy values using stoichiometric coefficients. Essentially, it is just difference in the standard state enthalpy (enthalpy of formation) values for reactant and product. If product has a higher value, then the heating value is positive, implying endothermic reaction.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
May 1, 2020, 12:00 |
Arvind Jay
Rep Power: 14 |
I wrote a small python code to compute the heating value of CH4 based on Fluent Std State values:
# Fuel CH4_molarmass = 16.04304 #g/mol CH4_std_state_entalphy = -7.49e7/1000 #kJ/kgmol @ 25 C CH4_Hf = CH4_std_state_entalphy/1000 # KJ/mol # Oxidizer O2_molarmass = 31.9988 #g/mol O2_std_state_entalphy = 0/1000 #kJ/kgmol @ 25 C O2_Hf = O2_std_state_entalphy/1000 # KJ/mol # Combustion Products CO2_molarmass = 44.00995 #g/mol CO2_std_state_entalphy = -3.935e8/1000 #kJ/kgmol @ 25 C CO2_Hf = CO2_std_state_entalphy/1000 # KJ/mol CO_molarmass = 28.01055 #g/mol CO_std_state_entalphy = -1.105e8/1000 #kJ/kgmol CO_Hf = CO_std_state_entalphy/1000 # KJ/mol H20_molarmass = 18.01534 #g/mol H20_std_state_entalphy = -2.418e8/1000 #kJ/kgmol @ 25 C H20_Hf = H20_std_state_entalphy/1000 # KJ/mol #Heat of Combustion Hc = ((CO2_Hf + 2*H20_Hf) - (CH4_Hf + O2_Hf))*-1.0 print ("Lower Heat of Combustion of CH4 = ", Hc, "KJ/mol") Hc_mass = Hc*1000/CH4_molarmass print ("Lower Heat of Combustion of CH4 = ", Hc_mass, "kJ/kg") print ("Lower Heat of Combustion of CH4 = ", Hc_mass*0.429923, "BTU/lb") CH4_density = 0.648 #kg/m3 @ 25 degC CH4_Heating_Value = Hc_mass*CH4_density #KJ/m3 print ("Lower Heating Value of CH4 = ", CH4_Heating_Value, "kJ/m3") print ("Lower Heating Value of CH4 = ", CH4_Heating_Value*0.0268392, "BTU/ft3") CH4_HV = CH4_Heating_Value*0.0268392 #BTU/ft3 Lower Heat of Combustion of CH4 = 802.2 KJ/mol Lower Heat of Combustion of CH4 = 50002.99195165006 kJ/kg Lower Heat of Combustion of CH4 = 21497.43630882925 BTU/lb Lower Heating Value of CH4 = 32401.93878466924 kJ/m3 Lower Heating Value of CH4 = 869.6421154294947 BTU/ft3 |
May 1, 2020, 16:14 |
Question
I am sorry, is there a question or you just wanted to share some information?
May 1, 2020, 21:27 |
Arvind Jay
Rep Power: 14 |
I was sharing the info.
But, I have another question: My intention is to simulate in Fluent with 100 % CH4 to mimic the combustion of Natural Gas which is 85%-95% CH4. The heating values of the two fuels are different and their air-fuel ratio are different as well. 10.9:1 vs. 9.5:1 (approx.) If I burn equivalent mass with same energy content (say 30000 BTU/hr): Will they require same oxidizer (air) amount? or Will the exhaust products mole fractions be the same? I have data of air exhaust from experiments for NAT combustion. But, I would like to simulate the furnace with 100% methane. |
May 2, 2020, 16:23 |
Air Requirement
The requirement of air will be as per the stoichiometric equation. If you use only Methane then air requirement will be as per Methane. So, if you use higher or smaller amount of Methane, air requirement will change accordingly, consequently, altering the mole fractions at the outlet.
combustion, fluent, methane combustion, methane/air |
Aerodynamic heating in Fluent | Oleg V. | FLUENT | 6 | July 22, 2019 12:41 |
Building problems with cell zones when reopening Fluent | MJ2017 | FLUENT | 0 | October 14, 2017 08:11 |
FLUENT Erosion DPM (Methane with Sand) - Strange Erosion Contours | chongjqw | FLUENT | 3 | February 22, 2015 21:17 |
Interesting problem: Parallel Processor VOF Fluent + Dynamic Mesh + System Coupling | spaceprop | FLUENT | 5 | September 2, 2014 09:43 |
Error in reading Fluent 13 case file in fluent 12 | apurv | FLUENT | 2 | July 12, 2013 07:46 |
